Sony Ericsson / Sony : Software, Firmware and Drivers : C510 CamDriver [M] Manual Mode v2.37
hello.. i try your cam driver n it work..
but there's a problem.. i only can zoom in VGA resolution
and there's warning when i try in 1MP or above "
zoom not possible in this resolution please try smaller size"
also i cannot move the focus manually by pressing left or right... FYI my FW R1HA035
thank for the help..
[ This Message was edited by: ivanoke on 2010-01-15 03:52 ]
Posted: 2010-01-15 04:50:41
"zoom not possible in this resolution please try smaller size" is available since the CID49 was implemented. This is not a problem. It was disabled some years ago by
In order to have the manual focus, you need to set the focus to INFINITE. Then change the values with the volume keys(+/-).
[ This Message was edited by: tranced on 2010-01-15 04:11 ]
Posted: 2010-01-15 05:09:29
@sec5100 when will next camdriver out? i'm waiting your great camdriver for C510
Posted: 2010-01-19 16:00:58
could you fix the language to be compatible with R1DA032?
Thank you so much!
C510 R1DA032 en.lang
Posted: 2010-01-19 21:00:24
You can add in the option setting ISO mode etc? Does the driver get out of the new cam. I would expect better. thanks..
Posted: 2010-02-01 12:01:29
Waiting for Manual ISO in newer driver cam
Amater
Posted: 2010-02-10 17:49:04
still not a good cam. does anyone here know how to remove the noise.. i really hate it..
Posted: 2010-02-16 07:11:42
does the camdriver manual mode discontinue? there'll be no update from v2.37 ? i want my C510 get a better shot..sigh
Posted: 2010-02-28 18:01:32
hey guys how come when i downloaded this file
"camdriver0.dat and en.lng"
i droped them in their proper place.
but when i turn on my c510
its not english and rather some other language.
can someone help me out please
thanks jgravity
Posted: 2010-03-20 15:05:02
Hi and welcome. What's your firmware version?
Posted: 2010-03-20 15:22:59
