Accessories
> Sony Ericsson MW600 Bluetooth Headphones
I bought today an MSI Starkey 3.0 BT adapter. Installed, but I cant pairing the pc with my mw600. What is the problem? Wrong BT adapter? Maybe software? Any ideas? :s
Posted: 2010-07-08 19:18:54
I'm using the same BT adapter. Working perfectly fine with my HBH-DS980.
You've to enter the default passcode "0000" for pairing it with the bt adapter, if you're on xp machine.
[ This Message was edited by: buntoo on 2010-07-08 19:46 ]
Posted: 2010-07-08 20:45:08
So, my problem is other... the starkey 3.0 original program dont find the headset. Im searching new device, but only finding the mobile (x1) but nothung other..
Im useing 7 ultimate + MSI original CD program.
[ This Message was edited by: Kasya on 2010-07-08 20:01 ]
Posted: 2010-07-08 21:00:12
Is your device in discovery(pair-able) mode?
Posted: 2010-07-08 21:10:20
in win options is available... yes
Posted: 2010-07-08 21:14:24
I'm using the same OS (Win 7 Ultimate 64-bit) and having no prob with my device..
Check on some other system if it works.
Posted: 2010-07-08 21:19:14
[ This Message was edited by: pt020 on 2010-11-22 01:59 ]
Posted: 2010-07-09 08:53:33
I have this MW600 headphones. Sound quality is very good. You can record songs from FM and worked perfectly over blue tooth giving stereo. You can listened to the integrated FM radio of the MW600 headset.
Posted: 2010-07-29 07:08:45
is there a white version that will be released? i got a black one for my white aino
Posted: 2010-08-09 05:29:16
how will i know if the phone is fully charged while charging?
Posted: 2010-08-29 18:48:42
