Sony Ericsson / Sony : Tips and tricks : Handler Mods Download Page
< Esato Forum Index > Sony Ericsson / Sony > Tips and tricks > Handler Mods Download Page Bookmark topic
Page <  123, 4 ... 161718>
anningg Posts: 78
hey i havnt had any succes downloading with the opera 5beta 2. its either the download remains at 0kb or the browser exits.any help
Posted: 2009-12-08 14:23:00
aquared29 Posts: > 500
another good collection in esato
thanks for that sitnet
it would be a great help
Posted: 2009-12-08 14:30:12
exaflare23 Posts: 227
brand & model of your mobile phone?
Posted: 2009-12-08 16:22:48
anningg Posts: 78
nokia n81
Posted: 2009-12-08 16:45:00
@anningg
In downloading you must consider some of the ff
1st "network provider" network traffic,network problem affects the downloading
2nd "weather" bad weather means weak signals, mobile phones depends on the signals
3rd "location" avoid sealed,closed rooms uhm! example air conditioned rooms,or in the bat cave
remember mobile phones depends,rely on signals.
4th "2G/3G" some mobile phones cant download using applications bcoz of its only 2G example s40 type nokia phones, 3G phones can download ofcourse but you must aware if your vicinity had a 3G signal & the examples above.
Posted: 2009-12-08 17:28:10
sitnet Posts: 325
Hey anningg!
No this probably has nothing to do with you network... I get the same problem. If I download a file in my default browser with the CGI dot trick, it downloads 100% at 50kbps (and free obviously). Then with exactly the same trick and file, but through Opera mini 5 beta 2 Handler, it doesn't download. Only if the file is smaller that like 20Mb it will download in Opera Mini. Otherwise not.
I think it is a bug because it does exactly the same with the unmodded version form Opera.
Posted: 2009-12-09 09:42:13
its just in beta not the final release thats why it had bugs
@sitnet
can i request for the new bolt 1.6 handler editable server tnx
Posted: 2009-12-09 10:25:47
sitnet Posts: 325
@sitnet
True about Beta, can't wait for final...
About Bolt 1.6 handler, I struggling to find it. It was only released on Monday this week so I am not sure if he has modded it yet. But go check out the new Ucweb 7.0 Final Handler (in english) on the first page.
Posted: 2009-12-09 10:35:33
@sitnet
how to operate ucweb final? im using flyproxy but it didnt work.
Posted: 2009-12-09 15:13:47
maze013 Posts: 24
hoew can i use the om50 beta 2 ??
whats the fbt ?
Posted: 2009-12-10 06:12:07
