Regional : Asia Pacific : RokTV.jar for Nokia S40 (litemint) with updated channels
Asia Pacific
tnx po sa mga additional channels,
hindi po working sa K810i ko ung mga Foreign Channels and ung DZMM.
Posted: 2010-01-07 09:57:00
@chua.. Sa ngaun di talaga gumagana yan, standby muna.. Just in case baka banda banda dyan... Hehehe
Posted: 2010-01-07 10:27:00
ung DZMM kc, gumagana xa pag built in gamit ko,
Posted: 2010-01-07 10:55:00
Teka lang ha
Lets make things much better, much easier
1st bakit kailangan ng prov file kung puwede naman imanual, (no hassle in downloading ng prov)
2nd bakit hindi built-in media ang gamitin instead na roktv kung puwede naman (no hassle in downloading and application error)
Advantages of built-in media
In using built-in you can select the type of orientation that makes you feel comportable, from portrait to landscape or vise versa (while watching huh)
In roktv you can only just watch in 1 type of orientation either portrait or landscape and you'll need to restart roktv in order to change type of orientation, and last roktv don't have the full screen mode.
In built-in you can easily set the volume just by pressing the dedicated volume keys
In roktv ???
hard to find
paano ba gamitin ang built-in media? 1st configure muna yung streaming settings for s40 at SE at sa mga symbian under real player nandun yung settings,
pano mag lagay ng channel?
every channel had their corresponding url ibook mark lang yung mga yun at pag gusto mo manuod just click those bookmarked urls of course lagyan nyo ng name para alam nyo kung anung channel,
ganun lang siya kadali, no downloading,no application error,no application not supported
Madami na ko nalagyan ng tv dito sa office mapa 2G or 3G, s40 or s60 at wala ako naencounter na problema sa downloading,application error,volume keys tulad ng nararanasan ng ibang tao na nababasa ko dito using roktv,
isang problema lang naencounter ko nakakapagod mag type ahahaha! lahat yun manual pati channels.
Posted: 2010-01-07 11:19:43
Nadale mo exa
Posted: 2010-01-07 12:17:00
Updated channel
Posted: 2010-01-10 09:35:00
Jejeje, tnx kua rh0n!
Posted: 2010-01-10 10:42:00
@anyone
my problema aq..dinownlod ko..pg instal ko invalid jar file..triny ko ko zip..pg extrak at instal ko invalid jar file din..n73 vodapo smart..reply pow..at pm jeje..
Posted: 2010-01-12 14:59:37
Nadownload ko na..pro buferng 33% tpos eror na..s60v3 n73..elp..di ko nlagay seting sa configuration kce wla aq nun..hangang aces point lng na ilagay ko..SOS
Posted: 2010-01-13 04:33:23
working to sa n73 ng utol ko...
You may download this rm file...
http://rhoncris.110mb.com/rokchannel.zip
just unzip the said file save to your cp and open the rm file
use this setting ha.....
Nokia S40 setting: used the setting above (manual or prov file)
Nokia S60 setting: open your real player first then go to option >> connection >> enable proxy
proxy: 10.165.127.21
port: 554
Posted: 2010-01-13 07:02:00
