Sony Ericsson / Sony : Windows Mobile : Annoyances and bugs in Xperia X2:s windows mobile 6.5 [updated 17 June 2010]
< Esato Forum Index > Sony Ericsson / Sony > Windows Mobile > Annoyances and bugs in Xperia X2:s windows mobile 6.5 [updated 17 June 2010] Bookmark topic
Page <  123 ... 1011, 121314>
rene Posts: 125
REmove that card immediately from your phone! The phone probaly tries to re-format that card!
Then boot into linux. This way I could read about 400Mb of my files (i lost 2,5Gb of musicfiles, but those I have on my Hdd)! If you don't have any linux, then download for example the ubuntu livecd: http://www.ubuntu.com/getubuntu/download
After booting with that CD, and iserting the SD-card with the adapter, Ubuntu should mount directly that disk to the desktop. Don't use windows disk-checking tools, cause they just mess things up!
Posted: 2010-04-23 21:34:12
prodjsxb Posts: > 500
Windows disk check worked for me to fix my corrupted file system when the same thing happened to me.
Posted: 2010-04-24 00:24:50
doministry Posts: > 500
Can you clarify what is that?
Posted: 2010-04-24 00:39:31
DrewVL Posts: 238
This is when he/she keep insert usb cable and pull it right out without proper method numberous times.
Posted: 2010-04-24 09:13:06
mathios Posts: > 500
today i opened emma and it downloaded a new version of the R1BA023 firmware version for the X2 I haven't installed it yet because I don't have time right now, but I will keep you all posted
update
as i mentioned yesterday on the above post I use emma not seus yesterday emma downloaded a new version of the R1BA023 generic_sg and i installed it last night the device is much more stable, I know that most of you will not believe it but it's true I have noticed many differences in the speed and stability of the device slideview is more stable it does not hang my x2 (until now) I am using the device with the default windows today panel and it's significantly faster and stable. I will need more testing for a few days to confirm this but I will keep all of you posted. as for the memory card disappearing I have never encountered this even in previous versions of other firmwares
[ This Message was edited by: mathios on 2010-04-24 09:05 ]
Posted: 2010-04-24 10:03:58
rene Posts: 125
Yes, this works, but it just converts the lost files into FileXXX.chk-named files. Via Linux i got the original files...
Posted: 2010-04-24 10:13:40
ingenus Posts: 69
Possible to obtain that firmware somehow?
Posted: 2010-04-24 15:03:31
ingenus Posts: 69
But then again, my Device info says, I already have R1BA023 - Generic_EN? Is there any difference at all?
Posted: 2010-04-24 15:25:57
kronos12 Posts: 72
There is no update, only MR1 so if any one has an clue or path where can be downloaded some cooked roms...please post here.
Posted: 2010-04-25 12:38:20
rene Posts: 125
Guys,
I got today from a preview-release of the MR2-update. Til now the phone has bee working really smooth, and i can't say anything else than that this IS the version the SEXX2 should have been shipped with from the beginning. More or less everything works quick and smooth. Til now i have not had any Black Screen Of Deaths, so it looks promising. Tomorrow I'll see how the phone behaves at the office!
SlideView is now a joy to scroll around in, also in the apps-menu and start-menu. Swapping panels is quick, and flipping throught them via panel-manager is like shuffling a card-deck. The only issue that came out is the lack of the motion-sensors. The only way to tilt the screen is to slide out the keyboard...
Posted: 2010-04-27 03:08:11
