Sony Ericsson / Sony : Windows Mobile : Annoyances and bugs in Xperia X2:s windows mobile 6.5 [updated 17 June 2010]
< Esato Forum Index > Sony Ericsson / Sony > Windows Mobile > Annoyances and bugs in Xperia X2:s windows mobile 6.5 [updated 17 June 2010] Bookmark topic
Page <  123 ... 91011, 121314>
prodjsxb Posts: > 500
Rene is right in what he is trying to put across.
Without any apps or any other flashy crap, the X2 should have performed all the functions advertised on the box without any problems. Hell, my X1 was buggy for sure, but it never decided to disconnect or corrupt the memory card in the entire time I owned it. More so I don't recall ever having to remove the battery to restart the X1 so many times either. If it wasn't for the poor quality build of the X1, I would still own it today. It certainly functioned more reliably than the X2
They had X1 to learn from, but it appears form comes before function in this case.
[ This Message was edited by: prodjsxb on 2010-04-19 21:44 ]
Posted: 2010-04-19 22:43:20
doministry Posts: > 500
Nobody argues here about the fact that X2 should work brilliantly.
I'm just saying WM itself is a good OS, that's it.
So X2 is a fault, not Microsoft.
Posted: 2010-04-20 00:41:56
amdx2 Posts: 38
we... apart from the memory card bit my phone works great.. freeze from time to time need to restart every few days other than that its great...
Posted: 2010-04-21 14:14:27
DrewVL Posts: 238
Seriously guys, having Windows in a smartphone is one of the dumbest ideas EVER! Why can't people realize that more or less ALL windows versions are copletely bloated and require apbsolutely too much from it's hardware?? Especially in devices that run on batteries this is just a stupid idea
whoow..that's a strong statement right there
to the point i do agree it's memory hawk but WM has lots to play with. ie custom rom and you can tweaks it as well. i myself like WM as im a owner of HTC HD2 and it's just awesome
X2 does have a bit of a problems, my friend own one so therefore i know but i believe there's an firmware release soon? the SPB shell? has cause problems for his phone so after uninstall it his phone very much stable now
[ This Message was edited by: DrewVL on 2010-04-21 13:41 ]
Posted: 2010-04-21 14:35:43
rene Posts: 125
to the point i do agree it's memory hawk but WM has lots to play with. ie custom rom and you can tricks it as well. i myself like WM as im a owner of HTC HD2 and it's just awesome
Well, if you get enough dissapointed in a device that runs windows, then you can't stop complaining..
I've heard a lots of comments and opinions about winmo, and most of them had to do with the fact that the device was slow and sluggish. Of course you get used to it, and can live with it, but if you have been using a normal phone (not smartphone etc), then you can't help noticing that everything is slow...
I recently used for a while the nokia 9300 "communicator" when waiting for the X2. That phone is 5 years old, and it's surpricingly fast compared to the X2. Of course you can't compare the network-speed, but the phone's functions where still quick (again compared to the X2)... The 9300 has a 150MHz processor, and the X2 has 528MHz..!
Posted: 2010-04-21 14:52:00
And I repeat again - it's not a WM issue!
I use X1 as my main device, which has 18 months now, on WM 6.1
and it is really FAST device!
Posted: 2010-04-21 16:48:38
DrewVL Posts: 238
Rene,
Honest i never use WM before HD2 is my first Windows phone and it not sluggish trust me if you have one then you'll know what im talking about and i honestly dont know about X2 just my friend has it n he does complaint but overall he is happy with it he said
Posted: 2010-04-22 01:55:27
kronos12 Posts: 72
Ok after two usage to the end(battery drops dead and phone turns off) now it still charging to infinity but after turning on phone from 97% now is showing 98% so for now l have to manage 2% to get full 100% maybe then it will stop charger after 2h like it supposed to
Posted: 2010-04-22 19:03:02
ingenus Posts: 69
I wouldn't be so sure about that. It might aswell be, that WM 6.1 is made more stable than 6.5. I tried all the advices that were posted for making X2 a usable phone, and found out, that only time phone responds fast and is stable is by using default MS theme with also default items on the screen. If I change the default view to show like Date, Messaging, SMS Toolkit or so on (START > SETTINGS > TODAY - Items) than telephone becomes laggy. It can not properly close windows - for example - if you click on a Time, make some changes to clock and then click exit, it won't shut down. Then I slide out the keyboard, and it closes. Same if I press a camera and then exit, camera window will still stay on, and I have to do that slide out move again. But by using the default screen with default items on it, it is fast, responsive, and I did not have a single sleep-of-death since using it. So this is a solution for me until 6.5.3 comes out.
But then again, a 600 € phone should be responsive, reliable and so on with all the features it hold, not that you have to find your own way to make it work.
And still I believe, it must be a software issue.
Posted: 2010-04-23 13:49:09
Okay, fcuk, this is enough!!!!
Today this X2 corrupted my whole mamory card!
Completely!!!!
I wonder if it is possible to make any action against SE.
This is too much.
GUYS BEWARE
It will happen to all of you sooner or later!
Make backups!
I had a stable device, but this happened
and was confirmed by other users too!!
I wonder if I return my X2 next week.
If not, this goes to the drawer.
I'm not going to use it until it BASICALLY works.
Posted: 2010-04-23 15:22:17
