Manufacturer Discussion >
Apple
> Does 02 Ireland iphone work on 02 U.K?
Does anyone know if 02 Ireland iphone's work on 02 U.K meaning if i put my 02 sim-card in a 02 Ireland iphone would it work and since they are one and the same network they should shouldn't they?
Posted: 2010-04-26 16:38:34
nope as the network id code that is on the sim for o2 ireland is different to o2 uk so it wont be usable.... buy a rebelsim though and it should work fine!
Posted: 2010-04-27 14:49:00
nope needs to be UK firmware flashed then unlocked, then it should connect but you will have problems and limited 3G connectivity, stupid, really.
Posted: 2010-04-29 21:11:47
