Manufacturer Discussion : Apple : Unlocking/jailbreaking a 3.1.3 (05.12.01) 3Gs Iphone
Manufacturer Discussion >
Apple
Done and all well! Stunning! Thing I like is everything else is still the same and ITunes works as it should.
Thanks guys
[ This Message was edited by: dougproctor on 2010-05-03 22:19 ]
Posted: 2010-05-03 23:18:36
Lads, I have an officially unlocked iPhone 3G. Would it be safe to jailbreak it? Has anyone with an officially unlocked iPhone done so?
I was absolutely adamant that I wouldn't jailbreak but have succumbed
Thanks
Posted: 2010-05-05 14:56:10
I jailbroke my 3gs immediately after it was officially unlocked by O2 with no issues.
Jailbreakling and unlocking are two quite separate things so there is no reason to be worried, but if there was an issue you simply do a restoer in itunes and you'll be back to where you are now
Posted: 2010-05-05 15:04:54
Thanks dude :thumb:
Mine is an official Italian unlocked iPhone here in the UK. Should still be cool?
Posted: 2010-05-05 15:05:49
go for it!
btw, is there a specific erason you want to jailbreak? perhaps an app you can't get in the store?
Posted: 2010-05-05 15:10:44
Nope. No particular reason other than I'm a bit bored
I wouldnt mind having inteliscreen though
If all goes pear shaped I can easily go back to the original firmware, right?
Posted: 2010-05-05 17:04:17
yes, just do a simple restore in itunes and you'll be back to where you are now.
Intelliscreen is the one thing I paid for and do miss now that I'm not jailbroken.
I'm hoping Apple will continue relaxing its rules a little so that this can be brought to the app store
Posted: 2010-05-05 17:14:00
Why are you no longer jailbroken?
I'm going to install:
Winterboard
Stacks
5 icon dock
Lock Calendar
Lock info
SBS Settings
Posted: 2010-05-05 17:23:05
because I'm running the beta 4 OS.
There is a jailbreak for beta 4 os but its only recommended for people who develop jailbroken apps as it apparantly has some issues that I'd rather not be bothered with
Posted: 2010-05-05 17:31:46
btw if you can jail break means you can get hold of your ssh files which means you can downgrade the firmware and update it to 3.1.2 soo it can be unlock
Posted: 2010-05-06 01:41:40
