Sony Ericsson / Sony : Windows Mobile : MR2 Update bugs, fixes, mods etc.
< Esato Forum Index > Sony Ericsson / Sony > Windows Mobile > MR2 Update bugs, fixes, mods etc. Bookmark topic
Page <  123
Mr486 Posts: 40
thanks! it works even thoug everything else looks like win95...the text input fields ar white and readable...
Posted: 2010-05-29 00:47:16
Mr486 Posts: 40
Applied the SD Card fix today since i experienced problems with RaceChrono app - a trackday application that saves to the SD card since the data logging easily takes a few MB's per session. Without the SD fix it stoppes recording when energysaving mode kicks in.
Fingers crossed but i hope this fix solves the trouble with SD card being disconnected...
Other alternative of course is to turn of the energy saving completely but I guess that will affect the the battery time
Anyone else using this app with MR2?
Posted: 2010-05-29 17:09:48
doministry Posts: > 500
Hmm, what are you talking about?!
Xperia Saturn Light is a great modern theme and very readable!!!
Posted: 2010-05-29 20:41:53
prodjsxb Posts: > 500
SE released their own CAB to enable the accelerometer.
http://rapidshare.com/files/393296824/AccelerometerSettings_X2.cab
Much easier than manually tweaking the registry
Posted: 2010-05-30 20:13:59
Mr486 Posts: 40
I have hade some troble with batterytime recently and noticed today that the X2 doesn't shut of properly. When i press ok to shut of phone the screen dims but there is still light in the left hand corner and the phone gets very hot. And during this state the battery drains very quickly
My resolution today is to first shut down and then take out the battery - something i have not been doing since the MR2
Any hints and tips to get rid of this behavior (that we all know from the Windows world on PC) is there any logs to check to see what application/process fails to shut down properly?
[ This Message was edited by: Mr486 on 2010-06-06 22:40 ]
Posted: 2010-06-06 23:39:34
Yes! I experienced the same...
Automatic key lock was the problem. When I set the password to it and made it
lock a device after certain time (no other option anyway) my device was not
closing properly.
Once I turned off this function, all seems fine.
A bug..............
By the way why not just use airplain mode?
[ This Message was edited by: doministry on 2010-06-07 12:35 ]
Posted: 2010-06-07 13:34:17
Mr486 Posts: 40
Flightmode seems to take less battery actually! (But I'd still like to be able to turn my X2 completely of when I want too...)
The games from the original release of X2 SW is now avaliable for download at PlayNow by the way
Posted: 2010-06-07 21:47:20
Yeah I already play Experiment 13
Posted: 2010-06-09 01:04:46
titus1 Posts: > 500
I do also love my X2 after the MR2 update.But i hope SE support for the X2 doesn't end here.
Posted: 2010-06-09 03:01:38
Please note! I will no longer be working on trying to fix any bugs on the X2.
I'm sending it back and getting an X10 instead, so my efforts will shift over to Android now.
Perhaps down the road when they come up with a better OS or something, I will buy another X2. Until then, I hope others who have been helping out now will continue to do so.
Posted: 2010-06-11 03:20:09
Page <  123
