Sony Ericsson / Sony : Symbian phones : BAM MOD (Basithz Acoustic Mod, Modification pack)
< Esato Forum Index > Sony Ericsson / Sony > Symbian phones > BAM MOD (Basithz Acoustic Mod, Modification pack) Bookmark topic
Page <  123 ... 8910, 111213>
eltoffer Posts: 348
On 2010-08-15 23:47:12, basithz wrote:
On 2010-08-15 22:59:05, eltoffer wrote:
why still no EARPHONE volume "fix"???
do you mean headphone sound???
as i said in the change log the sound has been increased to max (but cannot go any higher due to an audio leveler) so therefore i have increased it to the max allowed limit but i have also increased the sound quality.
actually i mean the EARSEPEAKER, if you mean this one too, i didnt notice any volume change
Posted: 2010-08-16 05:21:47
gharknes1 Posts: 231
the least SE could do if they are no longer supporting this phone is to allow owners the freedom to hack it/modify it if they choose to do so without having to go through a whole complicated updating process
Posted: 2010-08-16 11:05:10
mikely_28 Posts: 466
Yes!!! That's right!! If they can't do anything than let it do to someone else like users!!!
Posted: 2010-08-16 11:12:28
basithz Posts: 253
i haven't edited that file so thats why there is no increase for the in-ear speaker. personally i thinks it already loud enough ( a bit too loud for my liking) and also i dont want to edit the file that controls it because a) i dont know which file controls it and b) because i dont want to bust the in-ear speaker (this was a problem with the c905 before and i dont want this to happen)
so therefore i wont be making one for the in-ear speaker! sorry
Posted: 2010-08-16 13:56:49
DeadInside Posts: 6
i've installed the pack BAM v3, it acually worked , and the ringtone has increased a little bit.
but, there is no change in the sound from the sound recorder or the video recorder. i mean the sound in either sound recorder or video recorder is still (so low) as it was before.
(did anyone notice this?)
REGARDS...
Posted: 2010-08-16 16:16:27
basithz Posts: 253
REGARDS...
the sound has been increased, to see how much its increased by make a comparison when recording a video with c2z patch on in a controlled environment and then record one in the same environment with the c2z patch off. I can say that the recording sound has definitely increased. Also it might be that you could have installer it incorrectly so just reinstall BAM v3 and run the c2z patch hope this helps.
[ This Message was edited by: basithz on 2010-08-21 13:30 ]
Posted: 2010-08-21 14:29:59
Xajel Posts: > 500
Stupid Question...
If I want to have all features of BAM 2 & 3, do I have to install both or the newer BAM3 will be enough...
Posted: 2010-08-23 10:05:04
basithz Posts: 253
On 2010-08-23 10:05:04, Xajel wrote:
Stupid Question...
BAM v3 has everything that BAM v2 has but has but BAM v3 has new features and improvements from BAM v2. just install BAM v3.
Posted: 2010-08-23 10:43:20
Mr.Krypton Posts: 46
basithz frnd i need to hack my satio where to find helloo ox signed for free
Posted: 2010-08-23 11:32:48
basithz Posts: 253
IF you just want to hack it
here is the unsigned HelloOX2 http://www.4shared.com/file/1[....]8b8e/HelloOX2v203Unsigned.html
to sign it go here http://cer.opda.cn/en/ you have to register, then login and then put in your imei number, then you have to wait 24-48 hours (maybe more).
after you get it you need to sign it with freesigner http://www.symbian-freeware.com/download-freesigner.html
use the certificate and key you get from opda.
then you have to install HelloOX2 and run it.
then you may install BAM v3
IF your on the latest firmware without hack
Now you need to downgrade check this http://www.esato.com/board/viewtopic.php?topic=197767
after you downgrade you need to hack it by installing and running HelloOX2
after that you need to upgrade to latest firmware if you want.
then you can install BAM v3
Posted: 2010-08-23 14:58:28
