Sony Ericsson / Sony : GPRS, WAP, MMS and Email setup : Gmail on S-E W900i help please
< Esato Forum Index > Sony Ericsson / Sony > GPRS, WAP, MMS and Email setup > Gmail on S-E W900i help please Bookmark topic
ofiaich Posts: > 500
thanks jplacson,
what do you do after you unlocked from that page? Just try my W900i again?
Ofiaich
Posted: 2010-08-30 10:20:41
Hi wiifanatic!
Next, drag the file onto the Sony Ericsson File Manager icon on your desktop. Your phone should then ask you if you want to install a new certificate, push Yes. Try sending a email again and it should work
Could not get the S-E Desktop Manager to see my W900i using cable or Bluetooth. That's why I asked
Can I install the certificate to the memory card, and go from there?
I will re-install the S-E Desktop Manager and try again.
Ofiaich
[ This Message was edited by: ofiaich on 2010-08-30 09:48 ]
Posted: 2010-08-30 10:40:11
hihihans Posts: > 500
Hic
Posted: 2010-08-30 11:02:42
Hi! Yes, good whiskey that!
I successfully install the W900i software and am currently transferring music to the phone using Disc2Phone.
I also synched contacts and calendar successfully.
However when I drag Equifax Secure Certificate Authority.crt onto the Sony Ericsson File Manager icon on my desktop, I get the error message
" unable to load the configuration. "
Can I copy the certificate to the W900i's memory to make things work?
Ofiaich
[ This Message was edited by: ofiaich on 2010-08-30 13:23 ]
Posted: 2010-08-30 12:11:02
Hi!
I read this thread and this one and also downloaded
Equifax_Secure_Certificate_Authority.cer
getrootcert.cer
thawte_Premium_Server_CA.cer
thawte_Server_CA.cer
ThawtePremiumServerCA.cer
ThawteServerCA.cer
and bluetoothed them, to my W900i
But still no success.
I get a wrong mailbox or password error.
I have also tried use googlemail.com instead of gmail.com
Any ideas?
I will post this to the A Guide to get Gmail working on k800i (Send/Rec) so perhaps any ideas could be posted there!
Ofiaich
Posted: 2010-08-30 18:26:45
simpsons provided the answer, in this thread A Guide to get Gmail working on k800i (Send/Rec)
On 2006-11-26 15:39:26, simpsons wrote:
Obvious thing to ask... but I assume you have setup you Gmail Account via the web application to enable POP etc. (as the default is to have this disabled !) ?
Also I assume you are not on O2 payando ? (if so they restrict access to the servers.)
Other than that... no idea.
and O2 payandgo service confirmed it.
Ofiaich
[ This Message was edited by: ofiaich on 2010-09-04 17:31 ]
Posted: 2010-09-04 18:30:02
