Asia Pacific
> need proxy 4 n2600 c pls.help
Hmm..
Smart user aq at.. Madalas sa akin yan..
..Story..
Kapag may nagpapalagay sa akin ng Opera sa cp nila(globe)..
Twitter gamit ko and 80.239.242.xxx gamit pinapagamit q..
Minsan lang nagfe failed from my experience..
Try again lang sa link na nagfailed to connect.. No need for exit open..
..Possible Solutions..
Disconnect your gprs connection by pressing the end call key once then reconnect [cancel trick for globe]..
Yan lang masa-suggest q for now..
posted via n2600c-2 opmin 409 Quain Handler..
Low memory phone handler yan.. ^^,'!
Posted: 2010-12-12 16:43:00
@laicure hahaha yan talaga gamit ko sa paghahanap ng mga tricks bago ako magkaroon ng opera mini handler tawag ko dyan sa trick na yan ay select end trick ako kasi while connecting tsaka ko lang pipindutin ang end button
alam mo rin pala yan
ako kasi nalaman ko yan nung mag e exit sana ako sa opera mini habang nag connecting tapos biglang nag connect kaya ko nalaman yan
wooh story
ahm kung ganun tetestingin ko yan para hindi na ako mag e exit at open again
thanks laicure you're the men
Posted: 2010-12-12 16:56:28
@jLd
^^, u're Welcome!
Hmm..
Sabi nila..
Yang trick na yan..
"Kahit hindi handler, gagana opera mo.."
tama sila..
Hehe!
Grabe, smart nakakainis gamitin..
Kapag nagka cellphone akong maganda, mag glo Globe ako..!
Posted: 2010-12-12 17:14:00
Tol tama yan globe gamitin mo mas maraming trick kasi ang globe kahit 0 load hehehe mukhang mayaman author nitong thread dalawa cp eh may isa pa syang thread c209 ba yun .... Tambay ka paminsan minsan sa room ko sa tanungan dun nalang tayo mag usap dun ka nalang mag reply
Posted: 2010-12-12 17:26:56
setting nmn po para s bolt231handler., tagal ko nang gustong magyoutube d2 s cp ln eh., N7O po yung cp ko tapos smart po network., maraming salamat po
Posted: 2011-01-10 17:00:00
do you have setting for bolt1.62 for streaming and downloading and settings for opera2.06
Posted: 2011-01-10 17:18:48
Bolt? Hmm...
Actually, we do have the same problem.. I need bolt settings too..
I can't do trial and error on any bolt version because my handset is just a low memory phone..
.. I've only mastered Opera Mini 4.x and 5.x version settings..
For futher tips and ideas about bolt, go to "all about bolt.."
Good Luck!
Posted: 2011-01-11 01:08:00
tnry q ung s aquared ayw prn mgopen.ayw mgconnect s internet...
Posted: 2011-01-12 14:26:00
Not working po Lahat ng smart fbts ngaun..
(not that sure, malay natin..)
globe ang working..
Posted: 2011-01-12 15:46:00
hindi ko rin alam laicure. may load ako at the moment. pero last night ok pa naman. kumusta ang wapsite ni uchi? wihihi!
Posted: 2011-01-17 05:05:22
