Asia Pacific
> Tips for rooting your Android phone
di ako sigurado tol. di ako nagamit ng nlack market eh. pag paid application, ginogoogle ko na lang. madami namang maglipana na mga paid application na makukuha mo ng libre sa net.
Posted: 2012-03-18 17:14:31
Hi Sir rexidi, thanks for the droidvpn nga pla. Gumana na pla saken after butasin ang sim. Ask ko lang kung nagana wifi tethering sa samsung galaxy 5. Natry ko mg download sa market kaso may lumalabas na error na "your kernel dont have all the necessary features to run this program".ano kaya pwedeng solution dun? Thanks
Posted: 2012-03-21 15:55:32
Saka sir may solution npo ba yung fast drraining ng battery?bilis din kumaen battry nung saken eh.
Posted: 2012-03-21 15:58:32
tol ano pinagbibisihan mo? gawa sana ako ng self hosted site under wordpress since pwd multiple users if gawin kitang staff so makapost tayo ng android tricks natin as well as apps (paid or free)...
or pwede rin forum etc.. anything na ok
[ This Message was edited by: prynxx003 on 2012-03-21 15:29 ]
Posted: 2012-03-21 16:28:15
ala naman tol, ok lang sa kin maging staff. kaso tol ala akong stable na internet ha. dito lang ako cp ko nagnnet eh.
kung post lang at share ng kaalaman alang problema sa kin.
Posted: 2012-03-21 17:15:20
basa basa lang.
Posted: 2012-03-27 04:26:38
mga ser tanong ko lang po pano mainstall ung om6.1handler sa SGY? globe user po, nosebleed po kase ako sa vpn tsaka shy pa ko magroot (hindi kase saken ung unit) kaya handler na lang po muna tsaka na ung root
ask ko lang sir pano setting ng mgc sa sgy, thanks po ng marame
Posted: 2012-03-28 15:47:00
sori nadouble post, paki delete na lang po ung isa, sori
[ This Message was edited by: ei8ht on 2012-03-28 15:07 ]
Posted: 2012-03-28 15:58:00
just download the handler then save it in your memory card. den go to your memory card where you saved the handler, open it then install.
NOTE: be sure to check the UNKNOWN RESOURCES in the application settings.
Posted: 2012-03-29 17:12:42
@sir prynxx nainstall ko na po ung om6.1 sa mmc, ang kelangan ko po ung setting ng om like
http://www.globe.com.ph blah blah, hindi ko po alam kung anu at san ako maglalagay ng trick, sa fq ho ba o sa filter (by the way blank ung filter ko hindi katulad sa s60 na may nakasulat ng socket at http) sensya na newbie po ako sa android
ano po bang trick setting sa handler tsaka san po ilalagay? (hindi po kase sya katulad ng s60 na madali iconfig) tenks po sa reply, tenks..
tenks po pala sa tut, pabookmark po, ang daling sundan
[ This Message was edited by: ei8ht on 2012-03-30 06:26 ]
Posted: 2012-03-30 07:19:00
