Regional : Europe, Middle East and Africa : Early Christmas Tunneler
> Topic Locked
Esato Forum Index > Regional > Europe, Middle East and Africa > Early Christmas Tunneler Bookmark topic
Page <  12345678910>
Samurai@hacker Posts: 148
Ive askd for fbt frm santaclause hope he makes me happy
Posted: 2011-12-25 17:57:00
stresskid Posts: 0
Step One: Register With SSH Providers
Register with SSH server providers, there are a heck of them , you simply put the word “SSH Account” in the search engine box. I personally use a free SSH account from Rootshell , you may register to get yours by visiting their website at www.rootshell.be . When registering make sure you provide a reasonable and convincing explanation as to why you want to use their free ssh service. It usually takes three until four days before your application gets approved and you will get an email notification when your registration is successful . If otherwise your registration is rejected you will not get an email notification. From my personal experience , given it is a free service you will usually not get a stable connection, meaning you will get disconnected occasionally. If you wish to get the most out of SSH connection you’re advised to subscribe to paid SSH services.
Step Two : Configure Tunnelier SSH Client
Now you have installed Tunnelier on your computer, the next step is to configure it by setting the required parameters. Put in the server name or the remote SSH proxy server and port you will be using to connect to it in the host and port fields. Typically the default port is 22 though you may also use other ports such as 443, 80 etc . You may ask your SSH service providers what ports are available. Also don’t forget to fill in your user name and password with which you register with the SSH server providers next to the server menu and check the “store encrypted password in profile” box.
Next step would be to fill in your local proxy and port by clicking on the “proxy settings” if you surf the web behind company or school proxies . Set the proxy type to HTTP as most companies or schools use HTTP proxy as opposed to SOCK proxy. If you are accessing the internet directly just leave the proxy settings field blank.
Next : Configure Tunnelier to reconnect automatically just in case your connection get disconnected by checking the “always reconnect automatically” located in the options tab.
Next : In the Services tab enable forwarding option by checking the box in the SOCKS/HTTP Forwarding option menu and leave other parameters unchanged.
Next : Now Back to the login tab, and click on the login until you’re connected to the SSH server .
Wait until connection with remote SSH server has established indicated by the Tunnelier icon in the right bottom corner turns white from grey.
Step Three : Configure Your Browser to surf Anonymously
Now you have connected to the remote SSH server, the final step is to configure your browser to connect through remote server by setting your browser proxy settings to 127.0.01 port 1080. In internet explorer you can locate proxy settings : Tool ——> Connections ——–> LAN Settings ——-> Advanced
In Firefox : proxy settings is defined in the following Tool ——> Options ——–>Network ——-> Advanced.
Done!! ……. Now you can surf the web anonymously without leaving traces in your internet service provider, the visited websites or your company or school web server.
Posted: 2011-12-26 21:43:14
stresskid Posts: 0
hey guys well u cn use this if tunnellier deosnt wok fr u bt i tested it nd it woks pretty well ok u cn download cproxy whch i thnk u all knw nd change the http proxy port frm 3125 to 443 nd restart it u cn use it wth cellc its nt tht stable bt it browses nd downloads bt nt big file this method was tested by mi fr mre info u cn go to the cproxy forum under free speech scroll down u,l see cproxy in south africa u,l see hw to do it fully peace............nd enjoy
Posted: 2011-12-27 19:05:04
doellied2 Posts: 11
Thanks dude
Posted: 2011-12-27 19:09:09
stresskid Posts: 0
tunnellier works pretty well wth voda nd cellc wth mtn u jst nid to knw whch ports r open on it then u cn use it bt i cn cofirm tht it woks wth voda nd cellc thnx happy new year..................
Posted: 2011-12-27 19:10:39
hackerT Posts: 1
Hey guys, I was searching around for FBT and stumbled around something interesting, Check it OUT! freeWebBrowsingSA
[ This Message was edited by: hackerT on 2011-12-29 04:56 ]
Posted: 2011-12-29 03:24:00
b0ng0s Posts: 216
On 2011-12-25 01:28:00, Hacker89 wrote:
Hey guys. Its been months that i havent had time to really use chat side. Been busy producing demos for guys. The music is taking all my time. Popped in to say i havent forgotten u guys. Merry xmas yall
When are you coming back to esato? officially!
Posted: 2011-12-30 12:50:19
anyone got mfbt?
Posted: 2011-12-30 15:01:00
b0ng0s Posts: 216
On 2011-12-30 15:01:00, Samurai@hacker wrote:
anyone got mfbt?
yeah! register at http://sahacks.betaboard.net/
Posted: 2011-12-30 16:13:02
inferno1 Posts: 0
how do i use putty i dont get it and where do i get the ssh server and anyone got mobile tricks since pc is not working
Posted: 2011-12-31 10:59:11
Page <  12345678910>
New Topic   Topic Locked
