Regional : Europe, Middle East and Africa : Early Christmas Tunneler
> Topic Locked
Esato Forum Index > Regional > Europe, Middle East and Africa > Early Christmas Tunneler Bookmark topic
Page <  12345678910>
stresskid Posts: 0
Introducing the new and great tunelling software which has features of squid,tor,privoxy.vpn nd more proxy softwre its really east to use nd wok fr both 8.ta nd cellc it ws tested the software is called JanusVM go ahead nd try it i,l post the setting nd hw to run it on win7 later as i am very busy to type nw lol a simple google search will take u to their main site..peace nd happy new years
Posted: 2012-01-01 14:49:15
stresskid Posts: 0
hello guys i knw i said i would post the settings on hw to use this tunnelr software bt b4 i post them u nid to hve 2 thngs to mke it wok then whn u guys hve everythng i,l post thm 1st u nid to hve the software Janusvm then 2nd u nid to hve VMware-player- so tht u cn run this software
Posted: 2012-01-01 21:56:04
b0ng0s Posts: 216
I have all the tools now.
Posted: 2012-01-03 09:25:20
luthor Posts: 0
ok i figured out how to use janusvm its connect to the heita network bt when i open firefox it show cant connet to google check your internet connection mayb im doing sumthing wrong gona wait for ur tut stresskid
Posted: 2012-01-03 09:56:13
stresskid Posts: 0
> Let's say your PC NIC settings are as follows:
> IP: 192.168.1.100
> Netmask: 255.255.255.0
> Gateway: 192.168.1.1
> DNS: 192.168.1.1
> All you have to do is change the Gateway and DNS settings on your PC to:
> IP: 192.168.1.100
> Gateway: 192.168.1.102
> DNS: 4.2.2.2
> Any other PC on your LAN can do the same using the 192.168.1.102 address as
> their gateway and set their DNS to an external DNS server.
> OR if you want to isolate your PC from the LAN you could use:
> IP: 192.168.50.130
> Gateway: 192.168.50.128
> DNS: 4.2.2.2
> Notice the gateway address is now pointing at JanusVM, and the DNS address
> is using an IP OUTSIDE YOUR LAN. The reason you need your DNS to point
> outside your local LAN is to prevent DNS leaks. When the DNS server is
> outside your LAN, the DNS resolve request get's sent to JanusVM where it is
> redirected to Tor's DNS port.
Posted: 2012-01-03 11:19:35
stresskid Posts: 0
The setup is very easy. Just download and install VMWare player, then download JanusVM. Once you have the VM player installed then you can open it and load the JanusVM application (a .vmx file). Then JanusVM sets up Tor and Privoxy.
The next step is to enter into the Run window the path JanusVM will give you. It should look something similar to: \\\\10.0.2.15\\Setup\\Run.bat
Of course, the IP shown to you may be different. An icon will appear on your desktop called “JanusVM VPN” after the run.bat file finishes running, then Janus will give you a set of choices.
Show IP information
Configure IP information
Configure Anonymity + Privacy
Shutdown/Reboot
Check For Updates
Help
Quit
You should first choose “Configure Anonymity + Privacy“ . Janus will give you a list of privacy configuration, pick the one that says “Anonymous”. Janus will restart TOR and Privoxy and then your set.
How does it work?
JanusVM is powered by VMware, built on the Linux 2.6.14 kernel, and brings together openVPN, Squid, Privoxy, and Tor, to give you a transparent layer of security and privacy that is compatible with all your TCP based applications.
If you like JanusVM and decide to keep it running on your computer, you may consider giving a small donation to the developer.
[JanusVM] hope ur hepled nd this software ws tested on 5 laptops nd it worked well[img][img][img]
Posted: 2012-01-03 11:26:47
luthor Posts: 0
ok thnx for the info bro gona r u on a lan network or r using a wireless modem
Posted: 2012-01-03 11:39:07
stresskid Posts: 0
lan
Posted: 2012-01-03 11:39:59
luthor Posts: 0
ok im using a wireless modem it connects show the janusvm vpn on my destop and it connects bt no data gets send or recieved in firefox
Posted: 2012-01-03 11:43:55
stresskid Posts: 0
use lan woks beta
[ This Message was edited by: stresskid on 2012-01-03 14:50 ]
Posted: 2012-01-03 11:50:44
Page <  12345678910>
New Topic   Topic Locked
