Manufacturer Discussion : Nokia : Nokia Lumia 1020
< Esato Forum Index > Manufacturer Discussion > Nokia > Nokia Lumia 1020 Bookmark topic
Page <  123, 456 ... 106107108>
Bonovox Posts: > 500
From what I have read is towards autumn time
Posted: 2013-06-05 21:43:43
cu015170 Posts: > 500
On 2013-06-05 21:41:43, Del wrote:
It's there any info on when this is supposed to be released?
Official reveal at Microsoft Build in San Francisco later this month. Launch.. probably 2-3 months after that, and its very likely that this particular model will be AT&T exclusive for a while.
Posted: 2013-06-05 21:46:18
I surely hope not cos Nokia is gonna shoot itself in the foot again limiting their market with exclusives
Posted: 2013-06-05 21:48:47
^ it will be.
Why does the hump have to be a different kind of plastic ? On the 808 and the N8 they are metal, and needed to be because they act as the FM transmitter antenna...
But.. in this case.. I don't see a point. It will blend in much better if it was unibody.
[ This Message was edited by: cu015170 on 2013-06-05 20:52 ]
Posted: 2013-06-05 21:51:11
Hmmm,but is this real??
http://www.wpcentral.com/more[....]s-windows-phone-find-light-day
Posted: 2013-06-05 21:53:06
its real.
Q4 release
Posted: 2013-06-05 22:00:02
Del Posts: > 500
Well that's just pants if it's going to be an at&t exclusive for a while
Posted: 2013-06-05 22:01:41
But is that At&T exclusive just in America?? Will there be exclusives in Europe?? Surely this would be silly on Nokia's part as Windows phone is bigger in Europe than America
Posted: 2013-06-05 22:06:37
I am sure that there will be an international version.. 100% .. its a matter of time.
Its important to note that the loud speaker is no longer inside the hump, like on the 808.. so that would save some room. Also, the capacitors for the xenon and the actual xenon are probably smaller..
I think those are the two main areas from which they shaved off couple of mm .. the module itself is probably identical, which is great. No matter how shitty the jpeg processing is, the module will still produce decent jpegs
[ This Message was edited by: cu015170 on 2013-06-05 21:21 ]
Posted: 2013-06-05 22:20:36
Well,as it is similar design to 920, the 920 has speakers on the bottom. Wonder what the Xenon range will be?? It looks slimmer than the 808 Xenon
[ This Message was edited by: Bonovox on 2013-06-05 21:27 ]
Posted: 2013-06-05 22:26:01
