Sony Ericsson / Sony : Android : Sony Xperia Z1
< Esato Forum Index > Sony Ericsson / Sony > Android > Sony Xperia Z1 Bookmark topic
Page <  123 ... , 555556557>
sponse Posts: 252
well i really wanted double tap to wake, so yeah shame on sony.
as for root, it is fairly easy to do, and it wont void your warranty, so i see no problem in that.
Posted: 2015-04-30 22:56:44
ascariss Posts: > 500
My z1 received the update this morning and I was hoping it would solve some problems with my phone, mainly the random shutdowns I have where I am using the phone and all of a sudden the battery level drops to 0% and it turns off. I can turn it on again but then it does 2 things, either it tries to boot and shuts down because of 0% battery or it goes into a boot loop with the xperia logo. The strange thing is, the battery is never discharged, and mainly occurs in the 70% of battery life, but can be higher or lower.
After upgrading to 5.0.2 I hoped this might be fixed but it seems it has not with a random shutdown today with 72% Shame. I am resetting the phone today to see if this fixes it, if not, then I will try somehow to get it fixed by Sony but knowing my luck, the problems will not be evident when I send it out to be repaired and sony will not fix anything.
So I will mist likely have to buy a new phone, probably either the G4 from LG or maybe wait for this Z3 plus but then I can't trust sony anymore.
edit, well looks like the reset did jack, and the problem still exists, this is messed up. It went from 83% to 0%, amazing. All I did was try to take 2 pictures. Maybe the battery is faulty.
Not sure what to do now, ask Sony to repair it, which might take weeks; leave it and wait for Z3+ or Z4 in fall, doubt I can use a phone that doesn't function after 2 photos; buy LG G4 or just go for a Z3.
[ This Message was edited by: ascariss on 2015-05-21 20:25 ]
Posted: 2015-05-21 17:29:17
kriti9898 Posts: 20
sony z3 compact is best smartphone..........!
Posted: 2015-06-03 11:53:30
emerson_shei Posts: > 500
Sony Rolls Out Android 5.1.1 For The Xperia Z1
http://www.xperiablog.net/201[....]a-and-z1-compact-14-6-a-0-368/
Posted: 2015-09-15 07:35:03
moogoo Posts: > 500
Hey.. i just went through this and the battery is the culprit. i bought a new one and new adhesive strips to put it back together and now my z1 is like new. total cost was ~$50 USD with slow shipping from china. i suggest swapping out the battery but definitely get new adhesive strips for putting it back together.
Posted: 2015-09-16 05:14:57
Video Update (9.4.A.0.10) Brings Light Theme To All
http://www.xperiablog.net/201[....]-10-brings-light-theme-to-all/
Posted: 2015-09-16 05:25:20
Gitaroo Posts: > 500
after 5.1.1 update, my Z1 and Z Ultra finally feels like they way they should be. Or used to be .....
Posted: 2015-09-16 17:04:40
5.1.1 downloading for my device now, still no update for my z3 dual which is a bit ridiculous. Sony sure has a great way of updating their devices.
Posted: 2015-09-16 18:01:06
Posted: 2015-10-18 05:10:16
Posted: 2015-10-18 05:15:05
