General discussions : General : Best Android photography app
< Esato Forum Index > General discussions > General > Best Android photography app Bookmark topic
Bonovox Posts: > 500
I'll give it a shot(not pun intended there) I just want something with shutter speed and aperture
Posted: 2013-09-09 20:58:55
drinki Posts: 60
Hi,
If you know what you are doing, nothing beats Vignette.
Linky
Regards,
Posted: 2013-09-09 21:05:17
Thanks for the tip. Does it do manual controls though?? I do know how to use manual controls on cameras and long exposures etc. Am sure if WP has Proshot with manual controls Android must be able to do it
[ This Message was edited by: Bonovox on 2013-09-09 20:12 ]
Posted: 2013-09-09 21:08:31
drinki Posts: 60
YES! When it comes to controlling the camera, Vignette is second to none.
On a side note, the only downside I found - it's slow saving pics at times.
Posted: 2013-09-09 21:18:06
admad Posts: > 500
I did some research, and it seems like there isn't an app for that in Android Manual shutter speed settings must be allowed to change in hardware, but it seems like there aren't any Android phones that can do that, except maybe newer Xperia, but then devs are still working on it and I don't know the progress.
Another useful feature that the CyanogenMod team will soon bring is the control over Shutter speed. Currently, no Android handset offers an option to control the shutter speed of the camera. Controlling the shutter speed of your Android device can allow you take much better photos, provided you know a bit about photography. They can be especially useful in low-light situations, where you can drop down the shutter speed to the lowest possible so that the sensor is able to take in more light.
It seems like other CyanogenMod devices can also get shutter speed, not sure, but it's still in the works
Nokia is known for very good photography, so they implemented it in WP, +1 point for WP against Android.
[ This Message was edited by: admad on 2013-09-09 20:30 ]
Posted: 2013-09-09 21:27:03
The Proshot app did really good nightshots and improved picture quality but for some reason doesn't work on Samsung Ativ S. I will try finding a shot i once did with it
Posted: 2013-09-09 21:33:33
Cheers
Posted: 2013-09-09 21:42:46
usons Posts: 6
Perhaps you might be interested in creating a photography website at hPage - https://www.hpage.com. They have a really cool slideshow gallery there where you can show off your photos
Posted: 2018-09-28 10:01:30
souravmadaan Posts: 7
Camera FV-5 is good app for photography
Posted: 2019-04-03 06:03:01
michaeljohnn Posts: 20
Candy camera
Posted: 2019-12-28 11:02:19
