Manufacturer Discussion : Nokia : Lumia 1020 vs 808 PV vs any potential rival.
< Esato Forum Index > Manufacturer Discussion > Nokia > Lumia 1020 vs 808 PV vs any potential rival. Bookmark topic
Page <  123 ... , 212223>
Sassho Posts: > 500
^Hey - you'r very angry , relax mate. The life is fun and phones are joke
Good light is nesessary for big DSLR-s too if you want great detail. I shoot only on daylight , night I sleep , usually
The gadgets not matter for me, I shoot same things on same daylight - undrestand ? I'm not real photographer - shoot only for fun and pleasure.
Cheers mate , sorry for nice 808 quality compared with everything
Posted: 2013-10-28 13:32:05
false_morel Posts: 375
Don't worry, I won't get tensed or stressed over a photography discussion.. Was just starting to have enough of the same points repeated many times over in this same thread.
G1 is not a DSLR btw.. I won't compare a dedicated no-compromise product to general everyday have-it-all compromised product such as cameraphone.. Despite the low price of some entry level DSLRs, and relatively high price of some mirrorless cameras, I still consider the latter category as a compromise general user category and hence comparable to a cameraphone in a way. Mirrorless cameras are basically compacts with interchangeable lenses.
It makes sense to consider whether getting a compact or a mirrorless is worth it while smartphones nowadays are capable of some decent stuff on the camera side.
DSLRs on the other hand are bulky, heavy, and more about functionality than IQ btw. Things like fast AF with high reliable FPS, full manual controls with respective buttons for better handling, flash control, higher quality optics, optical TTL viewfinder, etc..
Mirrorless give the ability to use specialty lenses, but at a much smaller sizes, both body and glass, which is in other words a downsized package of the bigger DSLR, meant mainly for better mobility for those not interested in any pro like photography but just capturing that private moment on a quality device.
Well compacts and smartphones do fall basically in the same category.
We can only compare and discuss IQ though these different three categories. As for features, it's a user's choice what he needs or doesn't need.
And when it comes to IQ, there are certain basic standards to follow I think.
[ This Message was edited by: false_morel on 2013-10-28 14:18 ]
Posted: 2013-10-28 15:16:05
cu015170 Posts: > 500
808
Canon G15
Posted: 2013-10-28 23:41:25
Who is the genius who took the photos above with two full stops difference between the cameras?
And I asked you about the same studio test you bragged out at DPreview. Why dig some random photo which apart from the wrong settings, it could suffer some user errors in as well.
You claimed in that studio test that the 808's sensor positions it well ahead of any other smartphone and any smaller sensor camera. So go there, quote for us the comparison crops between the G15 and 808, especially at ISO 400 and 800, and explain to us again how the 808's bigger sensor puts it ahead.
Posted: 2013-10-29 11:59:47
Yes, for some strange reason the 808 is always given an unfair advantage
But either way the DPreview comp pretty much put an end to this debate, I am just waiting for them to test the oversampling algorithm which should put the 808 even further ahead.
Someone in the comments mentioned that the difference is the pencil painting is quite big..
And you think that a difference of 50iso can account for this, but a difference of 10% in jpeg compression does not ?
Waiting for the Nokia Black update to see if it gets any better..
[ This Message was edited by: cu015170 on 2013-10-29 14:49 ]
Posted: 2013-10-29 15:47:20
Bonovox Posts: > 500
http://www.wpcentral.com/noki[....]lumia-1020-support-coming-soon
RAW support coming
[ This Message was edited by: Bonovox on 2013-10-29 19:11 ]
Posted: 2013-10-29 20:10:39
We already saw some blurry 1020 shot made by you, and then from the same store you posted two photos where the 1020 pulled ahead in detail and you still failed to comment: (808 shot at 95 JPEG compression in both images shown below)
And also from other photos you posted:
You simply ran away hiding behind DP's studio test.
The same test which clearly shows the likes of the G15 superiority of the 808 with much smaller sensor and 5x zoom lens! The P7700 also beats the 808 with the same margin while this is with 7x zoom lens.
So you have to decide: We either take the studio test for granted and as the ultimate professional test as you claim (in reality far from it), or we ignore that and base our judgment on real life photos (also not the all reliable and conclusive test).
You can't nitpick whatever suits your preference. Practicing double standards is not a healthy hobby.
From ISO 50 to ISO 100 it counts to one full stop in terms of EV! Do you understand what this means?
For instance ISO 400 to ISO 800 also counts for one full stop. Or from F/2 to F2.8 and F/8 to F/11 both jumps making one stop difference; or from 1 second SS to 2 seconds, and from 15 seconds to 30 seconds both making one stop difference! You really can't have hard time understanding this basic stuff.
Although the difference in that studio is not all due to difference in this one ISO stop (especially as ISO 50 is not even a native ISO on the 808 afaik; but it still affects the SS to go one full stop higher)!
Then, I already told you that 1020 at status quo isn't delivering better end results than the 808 under all conditions. Especially for general close range subjects. Indoors under artificial lighting the 1020 gets even weaker. Reasons for that are well explained in this thread so I won't repeat all these paragraphs again.
The thing I am debating with you and all 808 fanatics over here, is the reason why 808 and 1020 behave differently and exchange places for better imaging depending on the conditions. You along with the others positioning the 808 better than everything out there from cameraphones to compacts to mirrorless cameras, and on a league of its own even, all due to its sensor and PV technology are not only exaggerating, but even totally lost into a world of delusions.
Yes, under several conditions the 808 at the moment delivers best images, but not all due to its sensor size and PV technology. While under other several conditions it clearly doesn't.
As to JPEG compression, it does make a difference regarding detail by omitting certain pixels as the compression ratio increases. But it doesn't affect other qualities of the image, especially at low compression ratios such as 85 and 95!
And yes, if Nokia get rid of this ridiculous excessive sharpening plaguing the 1020, and adjust its color rendering, it should then be positioned to beat everything out there under all conditions. So better wait for this Black update before throwing these totally stubborn stances. The 808 had its share of updates as well and these did address the IQ too!
To end, I really advise you to go with scientific testings (so far, DXOmark and IMAtest applied) whenever these are applied and not deny them due to one random photo making a joke out of yourself in the process!
Posted: 2013-10-30 01:47:59
Look, I am not the only one that sees the 1020 as the inferior camera..It really does not matter which test you look at, the general consensus is that the 1020 can't match the 808 in terms of IQ in most conditions. It does come close, and in some rare cases it might be a little better, but overall it is not an improvement over the 808.
This is important since it is supposed to be the "successor" of the 808, but it just doesn't seem like it can really do that.
We will wait and see what happens after the black update, but I doubt that it will be able to match or surpass the 808 in any meaningful way. The 1020 is handicapped to begin with. Even if we ignore everything else, the weaker xenon and the heavy side blur caused by the optics is enough for me to ignore it. Its just not as reliable..
The 808's IQ has not changes since it shipped.. all the improvements were around the gallery app and the camera UX, even if they change anything in terms of IQ it was subtle.
The 808 shoots at 64iso in auto mode.
You seem to be very knowledge, so maybe you can enlighten some of those ignorant people about how the 1020 has the better camera:
http://www.dpreview.com/forums/thread/3566015
Here as well
http://connect.dpreview.com/p[....]08-lumia1020-studio-test-scene
and here
http://forums.wpcentral.com/n[....]20/246495-lumia-1020-hype.html
It will be nice for you to join the ongoing debate, I feel like you can contribute quite a bit to it..
Most people seems to be confused about the whole thing
When I see improvement, I would happily acknowledge.
Such as here.. I just opened one of the RAW images Nokia posted and worked on it for a few mins in lightroom, and I have to say that I am satisfied with the result. Of course, I made it to my liking.. nice and smooth
Also I exported it in what I believe to be the ultimate resolution .. 12Mpix/100% jpeg compression
Now I need a landscape to work with.
Just imagine if they had RAW output from the 808...
Posted: 2013-10-30 04:10:39
That's why I opened this thread and started the debate in the first place. Because I feel the 1020 is being misevaluated by the general online base at least.
1020 has its problems which need to be addressed. It is inferior in several areas. Only that the blame is being put on the wrong side of the camera! Its hardware has nothing wrong in it (apart from those faulty lenses in some batches; which every phone has btw). It's Nokia's crappy work on the software part that is making the 1020 lag behind in the areas it is doing poorly in!
And I think it is important to point out the real causes so that Nokia get what they did wrong!
And it seems they did. Or at least I hope so.
Not in rare cases. Any landscape shot under any condition is not a rare case. For indoors, flash, and close range (not macro, but talking several or tens of meters only) the 808 does better.
In macro both the 808 and 1020 are poor.
If Nokia address all the crap they did in those algorithms, with that Black update, the 1020 may very well turn into a completely different camera.
I already experienced that with my 920. The Amber update made it a whole new camera!
This is the bias and nonsense I am trying to point out here. But will refrain from repeating the same points till the Black update is out.
Yes it had. Unless you are denying the official change log Nokia released and before and afters.
And I am not talking about FP2 only, the 808 had several updates.
But yes, nothing major was done. Only some optimizations and little enhancements. The Black update is supposed to change everything! And I must say it is needed. And would be needed also in the 808 case btw. 808 also has an aggressive processing philosophy. Going standard is the way.
Yes I know. Which is pretty weird in case ISO 100 is the base! And as far as I know, ISO 100 is the base on the 808. ISO 80, 64, and 50 are low ISO modes enabled through software manipulation, and not base ISOs of the sensor.
Here as well
and here
I don't take part in comment sections usually.
As to DP forums, I usually avoid going into debates there. Too many trolls, or ignorants coming in ruining otherwise good debates. I stick there to questions and feedbacks in the DSLR sections..
As to WPcentral, I should join eventually. Specially that the Nokia forum I am part of is dead now! Will have to join a Lumia or a WP forum.
Where did you get the RAW image from? And it does seem impressive.
With RAW, we don't have to worry anymore about whether Nokia adjust their crappy processing or not.
I don't need to imagine it! Since I know the 1020's hardware is more capable.
[ This Message was edited by: false_morel on 2013-11-02 14:44 ]
Posted: 2013-11-02 12:17:00
Sassho Posts: > 500
Not bad compare 808 / Canon , but 808 can more if use Camera Mod or "RAW" postprocess. Comments for 1020 - not bad as all , but bad lens and postprocess - strong noise reduction.
Posted: 2013-11-03 14:40:33
