Sony Ericsson / Sony : Android : Sony Xperia Z3 Compact Announced
< Esato Forum Index > Sony Ericsson / Sony > Android > Sony Xperia Z3 Compact Announced Bookmark topic
Page <  123 ... , 596061>
emerson_shei Posts: > 500
Sony Xperia Z3 Compact Vs Sony Xperia Z5 Compact
https://www.youtube.com/watch?v=T0GoJ6xIExE
Posted: 2015-10-17 19:00:24
goldenface Posts: > 500
I need a protective cover for mine. Any recommendations? I'm after the metal edge type cover.
Posted: 2015-12-22 00:11:51
Sony Xperia Z3 Compact Running Android 6.0 Marshmallow (Review)
https://www.youtube.com/watch?v=5mrysqBkys0
Posted: 2016-01-03 21:20:49
pt020 Posts: > 500
Have a new update,still do not know what it is,PC is busy.
http://postimg.org/image/5q843tg8h/
Posted: 2016-02-15 17:14:22
tranced Posts: > 500
Maybe February's security patches?
EDIT
These are the improvements:
- Improvements to volume and silent mode control, more control of your alerts.
- All new LinkedIn integration - increase productivity with intuitive Calendar and Contacts sync.
- Camera focus, speed and accuracy improvements in Superior Auto mode.
- Many new features for Xperia™ in Business, enhancing enterprise support for Xperia™.
- Now take pictures from the camera using Sony SmartWatch 3!
http://support.sonymobile.com/global-en/xperiaz3compact/software/
[ This Message was edited by: tranced on 2016-02-15 16:30 ]
Posted: 2016-02-15 17:28:43
pt020 Posts: > 500
Will post later some screenshots,but the Download takes very long time,45min
(or my connection is so bad)
[ This Message was edited by: pt020 on 2016-02-15 18:15 ]
Posted: 2016-02-15 17:31:04
GWoltmann Posts: 1
I'm glad they are going with the compact style, I hate chunky phones. Xperia™ Z3 Compact looks just the ticket.
No Led what's this? GWoltmann
Posted: 2016-02-15 23:32:02
Did you get there pt020?
Posted: 2016-02-16 00:24:42
fjcarlsson Posts: 162
I just did a factory reset of my Z3 compact and now it can't find my music. Everything else can be found on the SD card. Ideas, anyone?
Thanks
Posted: 2016-06-06 11:44:08
Supa_Fly Posts: > 500
Thanks
this new Android 6 and the upcoming one seems to screw around with data location on the MSD. Best solution ... use the PC with Sony Sync or whatever their desktop app is and have a song on your PC/Mac sync to the MicroSD it'll show you the location. Move your music there.
Alternatively use the file browser to locate where you music is ... then tell the music app where to look for new music and done. Rebuild your playlists.
This is PRIMARILY the reason for Streaming apps taking off because File Management Browsers make little sense when teh OS screws around with the simplistic and default location of data. Leaving the end user, non technically inclined, feeling bewildered. in iOS each app knows where to look for data IT managers and allows for a pointer where the OS knows where it manages system data accessible to the end user.
Posted: 2016-06-07 04:34:09
