General discussions : Rumours : Sony Xperia Rumors 2015
> Topic Locked
Esato Forum Index > General discussions > Rumours > Sony Xperia Rumors 2015 Bookmark topic
Page <  123, 456 ... 473474475>
Velexas Posts: 29
@amirprog, the thing is: why would SONY stop launching "the best of SONY" in every screen size at the same time? If Z4 is not launched simultaneously with Z4c, for the consumer the Z3c will not be the best of SONY in a "compact device" - there is a Z4!
[ This Message was edited by: on 2014-12-15 18:03 ]
Posted: 2014-12-15 19:02:07
red98 Posts: 22
Z3 compact is too problematic smartphone for me with lots of cons.
http://www.esato.com/board/viewtopic.php?topic=207210&start=555
http://forum.xda-developers.c[....]ria-z3-compact-t2884498/page30
So, what we see in Barcelona 2015 with 4,3" - 4,6" display ???
Posted: 2014-12-15 19:10:42
JohnnyNr.5 Posts: 357
@red a bunch of mini "flagship" devices with medicore specs. Xiaomi is rumoured to reveal a relatively well specd 4.6" device. And maybe a galaxy alpha successor. Time will tell
Posted: 2014-12-15 19:16:44
amirprog Posts: > 500
@Velexas
If you read the credible sources info then you can understand the compact will be announced once a year. also the main flag will start be announced once a year from z4. the best compact of sony will be z3 compact also after z4 released because they are different devices. just an example, when samsung release a new galaxy s the galaxy note is not inferior to galaxy s because its intended for different consumers. the compact is the best of sony until a new compact will be announced. nobody who wants a compact phone should care about z4.
[ This Message was edited by: on 2014-12-15 18:35 ]
Posted: 2014-12-15 19:34:44
bronxdude Posts: > 500
i cant wait to see Z4's tired omnibalance design *sarcasm*
Posted: 2014-12-15 19:41:35
Ebato Posts: 134
just look at Z3. suicidal move if you ask me considering project 0 from samsung. I'm almost sure it will look like plastic POS again, but whatever, the hype is there and Sony needs hype.
Posted: 2014-12-16 06:18:45
supercoolman Posts: > 500
xiaomi has to survive loads of patent suits first
Posted: 2014-12-16 07:20:38
Hilmawan Posts: 98
For me the omnibalance design on Z3 is pretty close to perfection and I have some ideas to make it better.
1. Replace the back cover with metal and use the 4
nylon corners as an external antenna.
They also can make a hole on the back for NFC contact point or other connectivity and cover it with tempered glass or high quality plastic.
2. Same design as No. 1 but with removable back cover like Nokia 515 and removable battery.
But if Sony stop using omnibalance design I hope
they will use the arc design.
Because not only arc design will make their phone
look unique and different or even iconic but also will
make the phone more comfortable to use in any position.
Posted: 2014-12-16 09:13:34
Gitaroo Posts: > 500
they should keep omni and merge with arch design, so every part of the phone is proportional, but I can't imagine if they do a Z4 ultra, Arch might looks odd. Also they back will probably be plastic again.
Posted: 2014-12-16 17:01:23
I would say explore the Xperia NXT design language. The S, P, U - that one is one of the best. Form the LED strip to the fit in the hands.
Add more colors like blue and red.
Posted: 2014-12-16 17:54:21
New Topic   Topic Locked
