Manufacturer Discussion >
Apple
> the Apple rumors thread 2015
Here's how Apple's Force Touch might work on the next iPhone
http://www.engadget.com/2015/05/26/iphone-force-touch/
cheers!
Posted: 2015-05-30 12:07:21
iPhone 6S Plus set to get Galaxy Note 4's killer feature
http://www.techradar.com/news[....]ote-4-s-killer-feature-1295657
cheers!
Posted: 2015-06-03 11:30:23
iPhone 6s release date may have just leaked
http://bgr.com/2015/06/08/iphone-6s-release-date-september/
cheers!
Posted: 2015-06-09 07:28:34
What iOS 9 tells us about the iPhone 6S
http://www.techradar.com/news[....]-leaks-ios-9-wwdc-2015-1296174
cheers!
Posted: 2015-06-10 20:08:45
Next-Gen iPhones Could Feature Strong Aluminum Bodies [Rumor]
By Tyler Lee on 06/10/2015
As it stands, the iPhone 6 and 6 Plus rely on 6063 grade aluminum which is actually not as strong compared to the Samsung Galaxy S6 and S6 Edge which uses a slightly higher grade of 6013 aluminum. However if the rumors are to be believed, the upcoming iPhones from Apple this year could see the Cupertino company use a higher grade aluminum which would make the phone even stronger and durable.
This speculation is based on a recent statement made by Catcher Technologies’ CEO Allen Horng who told investors to expect higher revenues in the next quarter thanks to smoother productions and “strong orders” for metal casings for new projects, and that he expects things to really improve in Q4 2015.
http://www.ubergizmo.com/2015[....]g-aluminum/?utm_source=mainrss
cheers!
Posted: 2015-06-11 07:36:06
iPhone 6S may feature selfie cam flash
http://www.trustedreviews.com[....]ne-6s-may-feature-selfie-flash
cheers!
Posted: 2015-06-12 08:10:37
The iPhone 6S could put on some weight
http://www.techradar.com/news[....]6s-could-put-on-weight-1297156
cheers!
Posted: 2015-06-19 18:21:34
iPhone 6S: Apple reportedly starts manufacturing the next iPhone
http://www.express.co.uk/life[....]acturing-Force-Touch-New-Model
cheers!
Posted: 2015-06-27 04:16:09
7/01/2015 @ 7:51AM
iPhone 6S Design Revealed In Massive Photo Leak
What will the next iPhone look like? Now we know…
The ever reliable 9to5Mac has grabbed a great exclusive by attaining the chassis for the upcoming iPhone 6S (factory leaks meant it also happened with the iPhone 6 last year) and its massive library of shots offer a mixture of disappointment and intrigue.
The Disappointment
Perhaps predictably the most underwhelming aspect of the leak is that externally the new iPhone 6S looks exactly like the old iPhone 6. No front facing stereo speakers, no USB 3.1 Type C connector (always unlikely), no change to the back for a dual lens camera and no switch of button positions (a few, strangely, wanted the lock button returned to the top).
It is also has the exact same dimensions (so no new cases needed) and this confirms Apple will be sticking with the 4.7-inch – and presumably 5.5-inch – screen sizes. The polarising antenna lines also still remain.
Given all the similarities in design, I would argue it is therefore virtually nailed on that this new model will follow convention and be called the iPhone 6S not – as some have speculated – the iPhone 7. With a number change tends to come a hardware redesign.
And yet this iPhone 6S chassis is still highly intriguing…
The Excitement
Here’s the good news: while the iPhone 6S may look identical to its predecessor externally, internally it is all change.
The big thing to note is the mounting points for the logic board and components are completely different to the iPhone 6. Where this just a minor upgrade Apple could slip a tweaked chipset, memory and battery all into the same arrangement but that is not possible.
The major reason for this is likely to be the extra space needed for the iPhone 6S and iPhone 6S Plus’ widely expected move to 2GB RAM, which will put it on a par with the current iPad Air 2. Both new models are also expected to be bumped to 12MP cameras, which may require a larger module.
continued;
http://www.forbes.com/sites/g[....]5/07/01/iphone-6s-design-leak/
more:
http://www.phonesreview.co.uk[....]ing-in-new-images-gives-clues/
http://www.digitalspy.co.uk/t[....]-look-at-apples-iphone-6s.html
http://timesofindia.indiatime[....]nline/articleshow/47893373.cms
http://www.digitaltrends.com/[....]metal-frame-reveal-no-changes/
http://www.techradar.com/news[....]irst-iphone-6s-photos--1298120
cheers!
[ This Message was edited by: difenbaker on 2015-07-01 13:45 ]
Posted: 2015-07-01 14:40:26
Leaked Foxconn Document Shows iPhone 6s with 2GB RAM, 12MP Camera
http://www.ubergizmo.com/2015[....]2mp-camera/?utm_source=mainrss
cheers!
Posted: 2015-07-02 18:01:19
