Sony Ericsson / Sony : Android : Sony Xperia Z5 Premium Announced
< Esato Forum Index > Sony Ericsson / Sony > Android > Sony Xperia Z5 Premium Announced Bookmark topic
Page <  123, ... 525354>
Tsepz_GP Posts: > 500
moogoo
yeah I can see many pro-iPhone reviewers blabbering about weight, couldn't careless, my Note 4 is around 176g, what's an extra 4grams.
Yeah, they will compare it to 4GB RAM phones, although the Note 5 and S6 Edge+ will count as 1GB RAM phones as they are soooo aggressive at RAM Management.
I will gladly take this over the S6 Edge+ and Note5. The 4K display, 3430mAh battery and design make it seem to be one of if not the best phones of 2015.
Going to find out from my potential future network provider when they will have this beast available.
Hear that it is not overheating and apparently it shot a 4K vid without shutting down. It sounds like Sony have done a fantastic job.
Any word on OIS in the camera??? Anyone???
Posted: 2015-09-02 17:39:26
wiraperkasa Posts: 295
No physical ois apparently
Posted: 2015-09-02 17:41:17
Xajel Posts: > 500
Tsepz..
I saw a video I don't remember from Btekt or cnet.. he mentions no OIS.. just software but very accurate and fast.. he was impressed overall
Posted: 2015-09-02 17:42:07
davidsic Posts: > 500
No optical stabilisation while all the other manufacturers are starting to use it in their flagships...
Too bad and good luck with hand-held low light shaking blur for stills
Posted: 2015-09-02 17:43:59
Xajel Posts: > 500
Here's it in action
On 2015-09-02 17:39:49, JohnnyNr.5 wrote:
On 2015-09-02 17:34:15, Xajel wrote:
Guys, any one saw a video for the fingerprint in action ?.. if not yet then share whenever anyone see please..
short video
https://youtu.be/H22QHqGVL0M?t=2m14s
Posted: 2015-09-02 17:47:27
Shino03 Posts: > 500
But to be honest, even with ois, shakes are not completely eliminated
Posted: 2015-09-02 17:55:17
Minimum 4k display for the next ultra
Posted: 2015-09-02 18:01:49
badassmam Posts: > 500
This is too pretty to ignore, it looks so much nicer than the Z5 which is nearly identical in looks. Great job by Sony. I think it will be a great performer, they have changed a lot of things.
Posted: 2015-09-02 18:04:48
ascariss Posts: > 500
Well engadget mentions this (correct link now)
http://www.engadget.com/www.e[....]remium-compact-hands-on-video/
This fancy new sensor is backside illuminated and has embedded phase-detection pixels. It's housed in Sony's first mobile camera module with a closed-loop actuator, and in front of the sensor is a new six-element 24mm lens with a wide f/2.0 aperture. If you're unsure what all of this means, I'll break it down for you:
Sony says that, thanks to the phase-detection pixels, the Z5 family can autofocus in as little as 0.03 second, claiming it's the "world's fastest autofocus in a smartphone." All we can say is it's very quick. The actuator helps with this by swiftly moving the lens to focus, and because it's closed-loop, it'll also offer better image stabilization, especially for video
There are some image samples as well from Sony it seems.
[ This Message was edited by: ascariss on 2015-09-06 18:20 ]
Posted: 2015-09-02 18:05:42
moogoo Posts: > 500
I don't understand why everyone is obsessed with physical OIS? What does it matter? If the results speak for themselves, who really cares about HOW it is stabilized as long as it is stabilized well. If Sony's closed loop + software solution destroys everyone else's physical OIS when it comes to actual results, does it really matter? Wouldn't you say that Sony's solution is better?
complaining about lack of OIS without examining videos and comparing simply means you just want to see buzzwords.
Posted: 2015-09-02 18:11:25
