Manufacturer Discussion : Samsung : Samsung Galaxy S7 Announced
< Esato Forum Index > Manufacturer Discussion > Samsung > Samsung Galaxy S7 Announced Bookmark topic
Page <  123 ... 16, 171819>
McKinley Posts: > 500
On 2016-05-18 13:25:37, difenbaker wrote:
On 2016-05-17 22:15:39, McKinley wrote:
I have an unpleasant heating experience with my Galaxy S7.
Sometimes when I am not using my phone and have a few apps running in the background, it gets way too hot. Even though the display is off it continues getting hot and drain battery really fast. The only problem seems to be close all the apps running, which ruins the idea of having 4GB of work memory.
I have the Exynos version one, if that helps anyone who knows anything about this issue.
Check out the ff links...
10 common Samsung Galaxy S7 problems and how to fix them
http://www.trustedreviews.com/opinions/samsung-galaxy-s7-problems
Does the Galaxy S7 overheat?
http://www.androidauthority.com/galaxy-s7-edge-overheat-683024/
Galaxy S7 Performance Issues: Is The Exynos 8890 Overheating During Stretched Gaming Sessions?
http://www.techtimes.com/arti[....]-stretched-gaming-sessions.htm
How To Fix Galaxy S7 Overheating Issue
http://recomhub.com/blog/how-[....]-overheating-issue/#gs.Gtm8UNA
Fix: Samsung Galaxy S7 Battery Drain/Overheating
https://www.orduh.com/fix-sam[....]-s7-battery-drain-overheating/
How to Fix Samsung Galaxy S7 Overheating Issue
http://godokmi.com/how-to-fix[....]g-galaxy-s7-overheating-issue/
How to Stop Your Galaxy S7 From Overheating
http://forums.androidcentral.[....]our-galaxy-s7-overheating.html
Hope it helps,
cheers!
[ This Message was edited by: difenbaker on 2016-05-18 12:26 ]
Thanks for the links!
The common tips to prevent the phone from overheating is to turn off the fast charging.
Ironically, it makes my phone stay cooler compared to when I use a regular charger.
Other than that I have taken some necessary measures. Now it runs cooler.
Posted: 2016-05-18 13:45:19
More rant incoming and from the most important department.
The camera in my unit at least, seems to be really bad.
I will upload some pictures later and you can see how everything turns blurry
EDIT:::
This is the best shot so far and I am not really impressed with the clarity.
https://goo.gl/photos/EHWF7kern8gkqRYs5
Furthermore, I have noticed some hot pixels too in other shots with strong background light.
[ This Message was edited by: McKinley on 2016-05-20 23:57 ]
Posted: 2016-05-20 20:59:09
difenbaker Posts: > 500
EDIT:::
Hi, umm.. blurry pictures can be a result of many things. Like if your hand moved just before you took the shot? Or that its not focused properly? Or worse, which I really hope is not the case, the larger and lesser quantity pixels of the s7 is the one at fault.
About the other thing... can you explain what you meant by 'hot pixels'? Is that like a small black spots on the picture? Or is it like small white spots?
cheers!
Posted: 2016-05-21 03:21:22
More pictures and it all look so unnatural with oversharpening and unsharped at the same time.
https://photos.google.com/sha[....]FBQVp3NHpkU09aQUtQZl9IdlhWeklR
and
https://photos.google.com/sha[....]F3NEdYblBTb1JhRlNzTGNiZ1J6dG9R
Posted: 2016-05-21 18:16:11
Samsung rolling out bug fix software update for Galaxy S7 and S7 Edge
http://www.ibtimes.co.uk/sams[....]date-galaxy-s7-s7-edge-1561350
cheers!
Posted: 2016-05-22 14:09:31
emerson_shei Posts: > 500
Samsung Galaxy S7 Vs ZTE Axon 7: First Look
https://www.youtube.com/watch?v=UN0vKgICa30
Posted: 2016-05-27 03:45:09
cheers!
i haven't received the update yet.
Is this for the global version (930f)?
Posted: 2016-05-27 14:37:50
cheers!
Yes !!!
Posted: 2016-06-01 04:30:03
ShortyPretty Posts: 55
Samsung Galaxy S7 Vs OnePlus 3 Camera Comparison
https://www.youtube.com/watch?v=lQFFas1MZF4
Posted: 2016-06-14 22:30:32
Weird, I didn't get the May security update nor the update that was mentioned earlier in this post.
However, I got the newest update with security update from June 1.
The new firmware for my phone G930F, is now FXXU1APEQ.
Posted: 2016-06-14 23:10:04
