Manufacturer Discussion : Samsung : Samsung Galaxy S7 Edge Announced
< Esato Forum Index > Manufacturer Discussion > Samsung > Samsung Galaxy S7 Edge Announced Bookmark topic
Page <  123 ... 232425 ... 272829>
Tsepz_GP Posts: > 500
On 2017-01-18 17:44:06, davidsic wrote:
You had the update via OTA without the beta test program ?
Nope, downloaded the Official FW from SamMobile.
Posted: 2017-01-18 18:07:28
Ranjith Posts: > 500
Does the AOD have the same features as the N7?
Posted: 2017-01-19 11:05:43
Yes, it now shows notifications for all apps be it WhatsApp, Instagram, Facebook etc...
Posted: 2017-01-20 16:53:07
Hey Guys,
Since my phone was purchased from the UAE, VoLTE is disabled. I would like to change the CSC to any that has VolTE & Wifi calling enabled. The "About Phone" section shows my model to be "SM-G935FD" whereas the PhoneINFO app shows it to be "SM-G935F". Are they the same? PhoneINFO also shows my FW & Active CSC to be XSG & available CSC Codes are:
ACR,AFG,AFR,BTC,DKR,DRC,ECT,EGY,KSA,LYS,MAT,MID,MR T,MRU,MTZ,MWD,PAK,SMG,THR,TMC,TUN,TUR,WTL,XFA,XFE, XFM,XFU,XSG.
Im on 6.0.1 and was wondering if I can change it to the following UK Nougat :
https://www.sammobile.com/firmwares/...FOXA1DPLT_BTU/
or this Indian 6.0.1 at least:
https://www.sammobile.com/firmwares/...FODD1BPJJ_INS/
Finally! Phew.
[ This Message was edited by: Ranjith on 2017-01-22 13:07 ]
Posted: 2017-01-21 16:32:55
On 2017-01-21 16:32:55, Ranjith wrote:
Hey Guys,
Finally! Phew.
Hi Ranjith
You can use BTU, I'd advise sticking to it.
Ensure you Load the whole ROM, so in Odin do all 4: BL, AP, CP and CSC, that is what I did. maybe also ask at XDA
Use Samsung Cloud for Back Up, it's in the phones Back Up & Restore settings, when it restores it restores your whole setup after the update
Posted: 2017-01-23 05:06:12
Thank you, Tsepz_GP!
So I can use BTU even though it isn't mentioned under my "available CSC Codes " eh? and SM-G935FD and SM-G935F are the same?
Thank you
Posted: 2017-01-23 06:23:17
Thank you
There's a guy who simply flashed the G935F ROM in the South Africa forum I visit on his G935FD, and it worked fine, but I would suggest making sure at XDA, as he doesn't post much and hasn't said much more after flashing.
Posted: 2017-01-23 17:26:41
badassmam Posts: > 500
http://www.phonearena.com/new[....]nk-line-of-death-issue_id90289
Posted: 2017-01-24 11:07:07
Got the Nougat update for my UAE device an hour back! Just getting used to it
hmmm...S7 was the only flagship from 2016 that dint have any HW defects. Looks like that isn't the case anymore. Even someone I know has this issue. Lets hope its just a certain old batch or so thats affected.
Posted: 2017-01-25 04:46:52
Congrats Ranjith! Welcome to Nougat
A mate if mine has thus issue, he kept blaming it on himself as he dropped the phone on a tile floor, so u sent him that link, thanks!
Posted: 2017-01-25 20:31:16
