Sony Ericsson / Sony : Android : Unveiling Xperia XZ Premium
< Esato Forum Index > Sony Ericsson / Sony > Android > Unveiling Xperia XZ Premium Bookmark topic
Page <  123 ... 858687 ... 102103104>
badassmam Posts: > 500
Just messing, my 320SE needs an engine rebuild so I'm getting rid and replacing it with a 320d M Sport....even the same colour because I just love them so much.
Buy a hybrid tablet with stylus, increase your productivity. Get a XZP alongside as your plaything.
Posted: 2017-07-25 10:36:42
Tsepz_GP Posts: > 500
320d is epic, F30 320d? Those Bavarians have some other kind of magic working in those Diesel Motors of theirs, I drove a friends E90 320d a few years ago, I was blown away by the torque, the damn thing just kept accelerating at an incredible rate from 1st all the way 6th gear, I kept over revving as I simply wasn't used to a motor getting near redline so quickly in each gear
The MD at my old work had a 2016 BMW X5 50d with that brutal 700nm toque tri-turbo engine, THAT has to be the most insane SUV I have ever been in terms of acceleration, not even a Jeep SRT has that kind of toque, truly mind blowing, the ultimate sleeper .
Posted: 2017-07-25 15:01:10
vivftp Posts: > 500
Hmm, I went to one of my carriers locations and got a new sim card. Can't say it's done much to help with my signal strength though
I've found if I go into a large grocery store or a houses basement my signal strength goes to shit. Calls either are choppy or just don't work at all. Dunno what else to do
Outside I can get 3-4 4G bars just hunky dory.
Posted: 2017-07-25 15:19:44
moogoo Posts: > 500
@XJ - your roxfit case shattered too huh? can't believe they charge so much for something so fragile... hope your next case is better!
@vivftp - that sucks. but if it makes you feel any better, i get poor signal in certain stores too. always have, always will. doesn't matter what phone i use. i think certain stores are built to block signals so they can force you on their crappy in house wifi. lol. i don' tthink there's anything to be done about it. just use the in house wifi and make a VoIP call.
Posted: 2017-07-25 15:26:46
This is seriously concerning, anyone else facing this? I am reading about poor signal in the BB KEYOne to, but that seems to be the phone in general for many. This is the first time I'm hearing of a Sony having bad signal.
Are you using a case? Some cases can absolutely destroy signal quality
Posted: 2017-07-25 18:22:09
aussieland1 Posts: > 500
This is just me guessing here but it could be that your carrier is using lower frequencies for indoors not supported by XZ Premium - European version anyway
Posted: 2017-07-25 19:36:41
vivftp Posts: > 500
This is the case I'm using:
https://www.amazon.ca/gp/prod[....]tailpage_o05_s00?ie=UTF8&psc=1
I've tried it with and without the case on with no noticeable affect on signal quality.
I can't rule out that there are limitations with my carrier, but I'll need to do more testing. My folks own an X Performance that came from my carrier, so I'll test it against that when I can.
Another thing I noticed, this phone doesn't say LTE up at the top ever, does it. Both in the settings and on the notification bar all I get is 4G. I suppose it's the same thing, but just figured I'd point it out as my parents X Performance does say LTE.
Posted: 2017-07-26 03:06:08
moogoo Posts: > 500
@vivFTP who is your carrier?
I have AT&T in the states and while the signal can be low in stores, it's extremely rare that I will lose a signal completely. usually if it's a very large building and i'm tucked away somewhere with a lot of metal around or thick walls. Otherwise, I usually have signal and it's usually at least H+.
4G is LTE. Funny thing is, the manual doesn't even list 4G has an icon and it's supposed to say LTE.
http://support.sonymobile.com[....]guide/icons-in-the-status-bar/
I would imagine it is a carrier limitation on frequency and such. damn north americans!
Posted: 2017-07-26 05:09:27
funkadopest Posts: 61
4G or LTE (which indeed are the same)icons depend on your firmware region and not your carrier...
Posted: 2017-07-26 07:06:50
moogoo Posts: > 500
@vivFTP - i just tested my speeds while on 4G with 0-1 bars of signal sitting in my home. I got consistently 40-45mbps downstream and 6-7mbps upstream. that's as fast as my cable internet!
@tsepz since you have a screen on time obsession..
[ This Message was edited by: moogoo on 2017-07-27 11:51 ]
Posted: 2017-07-26 13:40:28
