Topic Locked
General discussions >
Rumours
> Sony Xperia Rumours 2018
On 2018-01-20 19:20:58, Subhamstylo wrote:
Look like we are going to see non existent side bezels Like XA2..
But top and bottom bezels will be bigger than competitor if the dimensions are true!
Let's see what happens!!
Xperia XA2=75% Bezel
This XPERIA=81% Bezel
Posted: 2018-01-20 19:24:34
ASCARISS
LG G6 18:9 format Screen and Sony's New Flagship With 16:9 fotmat Screen, Sony's Sizes=Amazing.... and, is not Fake 5.7 inch like LG G7
Posted: 2018-01-20 19:34:20
R u insane he said we'll see bit more bezel than lg g6 and lg g6 is 78% bd ratio and how 5.7 inch or 5.4 screen acording to u is 81% bd ratio in 152 dimension !
Posted: 2018-01-20 19:36:04
He is using a 16:9 ratio for the screen, I used a 18:9 for my first calculation, I have updated an image with 16:9 which leads to 81.2%
It is uncertain which ratio sony will use, this "leak: shows 16:9
http://www.xperiablog.net/201[....]s-be-the-next-xperia-flagship/
but the dimensions for this new device and the leak are different.
[ This Message was edited by: ascariss on 2018-01-20 18:54 ]
Posted: 2018-01-20 19:48:58
Edge to edge design increases the screen/body ratio.
That is why XA Ultra has 75-76%.
Can someone please edit a XA1 and make it 5.7" 16:9 screen and dimensions of new phone?
So we can see how it looks..
I know design is probably not same, but just for curiosity.
Note 5 is 5.7".
Body is 15,32 cm x 7,61cm
Not sure if my calculation is right.
Top/bottom bezels would be 1,3 cm each.
[ This Message was edited by: Moe87 on 2018-01-20 18:56 ]
Posted: 2018-01-20 19:49:12
Based on outside dimensions the rounded corner would be of radius 3.75mm.
If screen is in 16:9, side bezel would be of 0.67mm and up and lower one would be of 13.21mm
If screen is in 18:9, side bezel will be of 3.79mm and up and donw one will be of 11.55mm
Second scenario seem more plausibe
Posted: 2018-01-20 19:50:56
AlvinZahranM Posts: > 500
The sony will have ~81% stbr and g6 has 78.6%.
G6 has 19.4 mm combined top and bottom bezels and the sony phone will have 26.6 mm t-b bezels.
G6 has 7.15 mm left and right bezels, and the sony phone will have 1.44 mm side bezels, which is incredible.
The new sony phone will maintain its dual stereo speakers from the last generation, and there will be a sony logo on the front, too. That's why the top and bottom bezels are a bit thicker than its competition.
Then, like previously announced phones, the fingerprint scanner is also moved to the back, that's why they could make the side bezels very thin.
[ This Message was edited by: AlvinZahranM on 2018-01-20 19:03 ]
Posted: 2018-01-20 19:52:05
81%
[ This Message was edited by: tk007 on 2018-01-20 18:53 ]
Posted: 2018-01-20 19:52:22
https://fccid.io/PY7-21831A/R[....]10-S1V3-FCC-Report-SAR-3721463
http://phonesabout.com/screen[....]lculator-for-smartphonetablet/
almost %81 but width dimension is a little weird if it's a 16:9 screen , 5.7 inch screen itself has 71 mm width.
Posted: 2018-01-20 19:53:10
Yes, it is weird, but they might curve the phone and its screen a bit to increase the stbr, like pixel 2 xl or s8.
Posted: 2018-01-20 20:02:08
Topic Locked
