General discussions : Rumours : Sony Xperia Rumours 2018
> Topic Locked
Esato Forum Index > General discussions > Rumours > Sony Xperia Rumours 2018 Bookmark topic
Page <  123 ... 546547548 ... 578579580>
skyXperia Posts: 175
On 2018-08-16 18:41:46, Moe87 wrote:
Can someome check if benchmark of H9493 is real of edited pic?
Geekbench
https://sumahoinfo.com/post-25200
You mean this one. It seems come from Reddit so I don't really trust it.
[ This Message was edited by: skyXperia on 2018-08-17 04:48 ]
Posted: 2018-08-17 05:40:00
hgautam Posts: > 500
Flip Cover for XZ3
Posted: 2018-08-17 11:11:12
Tizzo Posts: 240
Looks like XZ3 going to have curved edges...
[ This Message was edited by: Tizzo on 2018-08-17 10:29 ]
Posted: 2018-08-17 11:26:39
Quite confusing. Some times it feels like edge to edge like XA series and sometimes like curved edges.
[ This Message was edited by: hgautam on 2018-08-17 10:41 ]
Posted: 2018-08-17 11:39:34
Moe87 Posts: > 500
It is more like Note8 than XA.
Dual edge increses screen % compared to flat.
Posted: 2018-08-17 11:54:30
Ppl Posts: > 500
Carved corners of the case suggest a curved screen. Imo it looks good, a couple of notches better than the previous one.
Also the case leaks and earlier than usual render leak suggest that this phone will be released rather quickly to the market. Sony's Pie update schedule adds more to this. They usually release a phone before updating prev. gen.
Posted: 2018-08-17 12:22:26
Curved Screen..... That is the reason why I stay away from Samsung....
I don't know. Keep using my XZ1 and wait for MWC 2019
Posted: 2018-08-17 14:02:01
I doubt it's curved like the galaxy's. It looks like edge to edge like xa2 series and only the glass is curved. The case is designed as such otherwise it would be hard to use the screen at the left and right edges.
I don't like galaxy's curved displays either. It's irritating and hard to use around the edges.
Posted: 2018-08-17 15:38:24
Ppl Posts: > 500
The same case for XZ2 doesn't have carvings on the sides.
If this render is real, it looks like the screen is curved. Besides the metal frame is also thin on the sides thick on the other ends just like galaxies.
From the cases it doesn't look like the new one is significantly thinner just maybe 1-1.5mm.
Posted: 2018-08-17 18:47:47
badassmam Posts: > 500
Looks like the XZ3 back is less curved and flattens out, seems a lot thinner but that is because the flat back. Really not keen on curved screens, the most likely thing to break if you drop it, I see so many people on the train with cracked Samsung corners. Flat and recessed like the Z5 is the best so you can put it faced down, my XZ1C screen sides are heavily scuffed.
Posted: 2018-08-17 19:47:37
New Topic   Topic Locked
