Sony Ericsson / Sony : Android : Sony Xperia XZ2 Announced
< Esato Forum Index > Sony Ericsson / Sony > Android > Sony Xperia XZ2 Announced Bookmark topic
Page <  123 ... 1617, 181920>
xpr Posts: 326
On 2018-08-12 15:55:28, hgautam wrote:
Can you tell which is louder. XZ2 or 9+?
The S9+ is slightly louder, but the difference isn't that big. However, the XZ2's both speakers are front facing whereas the S9+'s only one of them is front facing. This means that viewing videos on the XZ2 produces a more immersive experience. Also, the dynamic vibration system is a neat feature when viewing videos.
Posted: 2018-08-23 22:29:46
hgautam Posts: > 500
Thanks for the reply
Posted: 2018-08-24 03:40:00
badassmam Posts: > 500
I've just ordered the XZ2 Compact and wanted to know if anyone uses USB-C headphones or hands free because I hate the idea of using the shitty dongle thing? I'm not into wireless, I like wired but wanted to know if I could get away with using an iPhone set for example.
Posted: 2018-08-30 23:02:22
I would suggest to just switched to Bluetooth ones with good battery backup. you can try for a while....
There is SBH90C from sony, you can you use wirelessly as well as with type C port.... Best of both worlds...
[ This Message was edited by: hgautam on 2018-08-31 01:49 ]
Posted: 2018-08-31 02:36:01
Thanks, will take a look but will most likely go for something cheaper in all honesty. I'm surprised that Sony don't have a wired alternative for Xperia owners.
Posted: 2018-09-01 19:50:38
Tibagy Posts: > 500
Sony Xperia XZ2 Vs Sony Xperia XZ3 | Full Side-By-Side Comparison
https://www.youtube.com/watch?v=dqlaDFwOaJI
Posted: 2018-09-09 17:10:19
@hgautam
I got me a dedicated USB-C headset and it was not good so I'm going to use the dongle and my old Sony headphones for the moment. I'm surprised that the likes of Sony and Beats have not got USB-C wired headphones.
@everyone
So I'm using a blue theme and my lock screen clock is blue and the notifications are white but when you have the lift to wake function on, as you lift the phone you get the white clock but the notifications are black. Is there a way to get that as your standard lock screen look or is it exclusive to the lift to wake?
Posted: 2018-09-11 15:43:19
Yes dongle was your only choice left I guess...
Posted: 2018-09-11 18:07:49
goldenface Posts: > 500
My phone is holding up well scratch wise, the back is faring less well than the front, which prompted me to buy a case. The blue Terrapin case goes particularly well with the silver version.
I picked up my old Z5 Compact today, which had been stored away for a while, as it was needed as a replacement for a friend's lost phone. Wow!! It feels half the weight of the XZ2.
Posted: 2018-09-19 22:33:41
Just downloading the latest update. Anyone notice any changes?
Posted: 2018-09-26 11:11:42
