General discussions : Rumours : Sony Xperia Rumours 2019
> Topic Locked
Esato Forum Index > General discussions > Rumours > Sony Xperia Rumours 2019 Bookmark topic
Page <  123, ... 343344345>
Archdragoon Posts: > 500
Thank you !!
Posted: 2018-09-13 00:30:48
Mahdibt67 Posts: 25
https://www.gsmarena.com/sony_xperia_xz3-review-1822.php
Perfect battery,better algorithm in camera,loud speaker, but disappointing display brightness and delta E in standard mode testing
Posted: 2018-09-13 16:07:03
Moe87 Posts: > 500
To avoid burn in as much as they can. That is why I prefer LCD.
You can use 100% brightness 24/7.
Tech site of my country could push XZ2 to 872 nits.
Delta of XZ2/XZ2P ar lower.
Posted: 2018-09-13 16:21:51
Nevewolf Posts: 128
It's reasonable, Samsung Adaptive profile is terrible.
Posted: 2018-09-13 21:21:29
Mahdibt67 Posts: 25
You're right lcd is much better
Posted: 2018-09-13 23:05:49
Mahdibt67 Posts: 25
Yes professional mode should be the most accurate one
Posted: 2018-09-13 23:22:48
AlvinZahranM Posts: > 500
Link?
Posted: 2018-09-14 07:56:17
hgautam Posts: > 500
Maximum brightness doesn't matter much.... How many of you always use your phone at maximum brightness while indoors??? Without auto boost S9+ has lower brightness than XZ3 which means when indoors the XZ3 can be brighter. And as for outdoors, XZ3 and S9+ have the same sunlight visibility score so they are equally bright in sun light. So in real life the XZ3 display is atleast as bright as the S9+...
As for color accuracy there are a lot of settings to just manually tune it to your liking. The default mode should have the most accurate colors white balance which sony doesn't does. But atleast we have options to tune it.
[ This Message was edited by: hgautam on 2018-09-14 09:56 ]
Posted: 2018-09-14 08:00:01
There should be some tool (hardware) to do the screen calibration for smartphone lol
[ This Message was edited by: Archdragoon on 2018-09-14 07:07 ]
Posted: 2018-09-14 08:06:29
Lonewolf223 Posts: 361
At least sony took a good step in adopting oled.
And samsung has the best calibrated displays in the market
In most of the reviews sony phones are said to have a bluish tint and even after custom white
point adjustments they arent that great
Sunlight legibility has improved by a great margin and this is the best sony phone in that regard.
They should crank up the brightness to somewhat around 600-700 nits
Current brightness is bit low for a flagship
Posted: 2018-09-14 13:13:05
New Topic   Topic Locked
