Topic Locked
General discussions >
Rumours
> Sony Xperia Rumours 2019
On 2019-03-26 07:42:14, Fisher wrote:
@ZodiacX
Japan only or not?
japan only.
Posted: 2019-03-26 08:10:17
On 2019-03-23 15:31:01, Hawk12 wrote:
How can ppl feel that slow?
Z phones have weaker cpu and still can handle all apps.
New Motorola is 21:9 with ugly hole.
Let's see if any site will complain about the screen.
😏😏😏 , we know the answer.
Z phones used older OS, with older Apps, that OS and Apps were designed with the power of their SoC in mind.
With new hardware comes, the OS and App developers evolve to make use of it, this makes the high-end phones good but the low-end phones suffers. That's why Google started the Android One program, even Android One specific applications as a lightweight versions of the same app.
Posted: 2019-03-26 09:05:51
That's Android Go not One. Also 630 + 3gig is not bad enough to show problems in the ui. It's either glitchy software or some hardware incompatibility. Or most likely to be just s#!tty sw.
Most android one phones run smoothly without any specialized app. All Nokias are in android one program. Only the lowest end suffers which has significantly less potent hardware than 10.
[ This Message was edited by: Ppl on 2019-03-26 09:03 ]
Posted: 2019-03-26 10:02:32
On 2019-03-26 05:44:25, ZodiacX wrote:
On 2019-03-16 02:55:44, Broccolee wrote:
how soon?
Xperia 4, it will be announced in May.
OK, so it is going to be released as one of summer products.
But zackbucks say there will be only 1 xperia for docomo this summer.
Posted: 2019-03-26 11:37:04
AlvinZahranM Posts: > 500
https://www.mobileworldlive.c[....]ny-shuffles-mobile-deckchairs/
Posted: 2019-03-26 12:58:43
Last week someone explained me about why pixels are RGB.
P30 Pro sensor uses RYR setup.
They say it provides better quality than RGB.
I have never heard about sensor with yellow pixel before.
Posted: 2019-03-26 13:56:25
https://www.sony.co.jp/SonyIn[....]Press/201903/19-027/index.html
Posted: 2019-03-26 15:00:44
If but I'm not sure, Sony provides Huawei P30 Pro with sensors and cannot sort their own stuff out it'll be a disgrace. Even though I can't stand Huawei, they have done great things recently.
Posted: 2019-03-26 15:00:55
When you said pixels I assumed display pixels. While sensor color pixels are also similar in using rgb, they have way more complicated calculations. And since they are used to capture light instead of emitting it, yellow might work as well. I've never heard a yellow filter sensor either. Huawei probably has a different way of color calculation.
@badassmam, i don't know for sure but I think I've read something about some center in China where they work together for sensors. You're also right, if they can't sort their stuff out it'll be a shame. Though I am optimistic about the future when enough time is passed for custom sensor and software development with aube.
Posted: 2019-03-26 16:08:29
I saw samples of new huawei.
There was a fear of colour reproduction being affected because of the 50% being yellow.
I do not liked the WB, washed out to me.
Can someone please tell when Sony plans to move from this tiny 12MP?
Waiting 3 or 4 semesters again will be stupid.
Score tech sites gave to X10
- techradar : 7.0
- trusted reviews : 7.0
- digital trends: 6.0
- iphone arena : 7.0
- androidpit : 7.0
- gsma: 6.4
Usual score for all midranges ...
[ This Message was edited by: Hawk12 on 2019-03-26 23:11 ]
Posted: 2019-03-26 16:50:27
Topic Locked
