General discussions : Rumours : Sony Xperia Rumours 2019
> Topic Locked
Esato Forum Index > General discussions > Rumours > Sony Xperia Rumours 2019 Bookmark topic
Page <  123 ... 311312313 ... 343344345>
Lonewolf223 Posts: 361
Just saw the comparison of xperia 1 with other top phones when it comes to performance
Bit disappointing for me
Sony should do better in this regard
https://m.gsmarena.com/gaming[....]ng_performance-review-1957.php
Posted: 2019-07-19 19:42:28
Hawk12 Posts: > 500
Dont trust OnePlus, Xiaomi , Nubia etc when it comes to benchmarks.
We have seem a lot of phones that came with software to keep pushing cpu/gpu no matter the heat when benchmark is detected.
4K screen , glass body and waterproofing contribute to make harder to lose heat. There is no surprise.
For example if you measure device's temperature while playing video 720p, 1080p, 1440p and 2160p you will see that at 4K it will be hotter.
Xperia Z4 Tablet did not suffer with heat unlike Z3+.
Big body made out of plastic.
Posted: 2019-07-19 20:28:41
U are deviating from the subject
Did u even read thr article
Dont be such a fanboy
Most flagships nowadays are glass metal sandwich including oneplus
I was talking about the performance drop observed in the xperia which was something that i wasnt expecting
By comparing it to one plus there is a clear difference
Hope sony takes these into consideration in their future phones
Posted: 2019-07-20 04:34:42
moogoo Posts: > 500
you guys are deviating from this thread. did you even see what thread you're in? RUMORS != Xperia 1
Posted: 2019-07-20 05:04:21
Hawk12 Posts: > 500
I said higher res , waterproofing and glass contribute a lot.
They tested OP7, not OP7P.
Except X1, all are 1080p.
If you put SD855 inside 10+, results will be better than 1.
In Taiwan, 6.1% of phones sold were Xperia. Then in june Xperia counted 7,6%.
Sony was #5 in May, then #3 in June overtaking Oppo and Asus.
https://www.eprice.com.tw/mobile/talk/102/5374742/1/
X1 to the rescue !!!!
https://sumahoinfo.com/post-33301
https://sumahoinfo.com/post-33266
https://xpericheck.com/device/J8010
https://sumahoinfo.com/post-33015
Last post is about a weibo post that says j80xx was going to be 1 5G, but cancelled and replaced by J89. But then why would firmware be out if it was cancelled? Does not make sense.
[ This Message was edited by: Hawk12 on 2019-07-24 12:04 ]
Posted: 2019-07-20 07:40:09
Nevewolf Posts: 128
because according to that filtration the cpu will be the same, we do not know how different it will be, it could refer only to the design and if that is true then the software is not completely discarded.
Posted: 2019-07-24 21:02:56
Hawk12 Posts: > 500
https://www.weibo.com/1136063370/HF44Tne8k?type=comment
Posted: 2019-07-25 11:14:10
badassmam Posts: > 500
By Compact its probably max 6 inch at that aspect ratio or it becomes too small. A friend told me that for it to be considered to be Compact they "wouldn't make it wider than the XZ2 Compact" so someone do the maths and see how it turns out. I don't believe it would be called Compact, probably 1x/y/z or something like that. I think there will be a 5G Xperia 1 refresh September.
Posted: 2019-07-25 11:34:05
Hawk12 Posts: > 500
XZ2c has 13,7 x 6,5 cm.
Let's suppose they can keep the same width.
Even with taller screen, the bezels would be smaller than XZ2c.
Maybe they can keep same height too.
Would be amazing.
Posted: 2019-07-25 12:46:51
Ppl Posts: > 500
That makes 5.8" 21:9
Which the earlier rumor suggested. It has the same width but no way they can do it under 140mm. Display only is 13.5cm.
Posted: 2019-07-25 12:51:39
New Topic   Topic Locked
