Sony Ericsson / Sony : Android : Sony Xperia 5 Announced
< Esato Forum Index > Sony Ericsson / Sony > Android > Sony Xperia 5 Announced Bookmark topic
Page <  123 ... 101112 ... 141516>
doministry Posts: > 500
On 2019-12-19 22:14:39, Luca-S wrote:
Use MyPhoneExplorer (app + windows program)
There's a option to backup your call log and SMS.
To restore, just install the same app on your new device then restore.
You'll need to turn on USB debug and drivers installed.
You can connect using wifi or USB cable. (which I prefer)
So there is no Sony solution? What about Xperia companion?
Posted: 2019-12-19 23:02:53
Luca-S Posts: 278
Let me test, in a few minutes I'll let you know if it worked.
Posted: 2019-12-19 23:35:18
tai020381 Posts: > 500
Think you backup to your Google account? Think it has (or I'm wrong ?)
Posted: 2019-12-19 23:36:04
Luca-S Posts: 278
You can't do it anymore (using Xperia Companion).
The new Xperia's don't have the Backup & Restore options under settings.
I tested using MyPhoneExplorer and it worked well. It's a nice tool that works with any Android phone.
With Google Backup you can do it too but it saves almost everything. (with MyPhoneExplorer you can choose what to save)
Posted: 2019-12-19 23:58:53
DentyCracker Posts: 116
MyPhoneExplorer has been around forever. Fantastic that it works with Xperias. I remember using it with my K700
Posted: 2019-12-20 03:52:55
goldenface Posts: > 500
Great thanks.
Posted: 2019-12-20 06:21:37
So I hacked the system a bit...
Downloaded the XperiaTransferMobile apk, and used it on my Xperia, nów it is on the system 😊
The Phone seems amazing.
BUT: I can use 3 cameras ONLY on auto?
[ This Message was edited by: doministry on 2019-12-20 09:15 ]
Posted: 2019-12-20 10:13:23
Nope. Only the UWA is auto. The other you can change to manual mode. If you start camera and hold your phone in camera horizontal position its on your bottom right for thumb to access. There will be a few different modes. Choose manual.
Posted: 2019-12-20 13:50:44
Choosing manual reverts back to the main camera. How to use other cameras on Manual?
Posted: 2019-12-20 16:38:58
Hawk12 Posts: > 500
As far as I know only main has manual mode.
At least it is what was said about 1.
Posted: 2019-12-20 16:46:55
