General discussions : Rumours : Sony Xperia rumours 2021
< Esato Forum Index > General discussions > Rumours > Sony Xperia rumours 2021 Bookmark topic
Page <  123 ... 232425 ... 737475>
cableguy Posts: > 500
New compact on the way
https://www.voice.com/post/@o[....]fans-need-1611507056-509494028
Posted: 2021-01-24 17:44:29
Hawk12 Posts: > 500
@onleaks posted a notched Xperia. Probably Ace II ..
www.voice.com/post/@onleaks/t[....]fans-need-1611507056-509494028
They are not going to change CPU of Pro.
Just the higher clock is enough to change whole software, do it all over.
People interested in it, want to take advantage of 5G and hdmi.
CPU does not matter.
870 is not even new chip.
[ This Message was edited by: Hawk12 on 2021-01-24 17:10 ]
Posted: 2021-01-24 18:01:55
Ppl Posts: > 500
This screams entry level. The chin and thickness suggests an LCD display, a 13mp camera? Probably a Samsung sensor. An L5? The cameras are inwards too just like the older L. They only notched the L last year. And this looks like a 2:1 aspect ratio. And it's still bigger than most people consider compact. IMO it's a good size, only if they've used oled, less chin and was thinner with a 7 series chip.
If you're gonna use a notch, at least justify it with a better front cam too. Can't be more than an entry level, or could even be Japan only.
Posted: 2021-01-24 19:31:58
Hawk12 Posts: > 500
Maybe it is the device rumored to use SD480. 5G chip for low ends.
Too small to be L5.
Sony has many 13MP, those 1/3". Ace has same main camera used by 10+/10ii ..
Posted: 2021-01-24 19:39:47
Ppl Posts: > 500
I know they have 13mp, they used it in XA. But L3, L4, 10 did not have one single Sony sensor in them. This seems closest to Ace, could be the entry 5G phone but this is not a regular compact. Maybe L5 compact, Ace2 (Sony could name it Ace 1) or they could name it Xperia 100 or 10 compact (don't think mark 3 could be used). It's a a shame tho, the overall shape is pretty nice.
BTW if this is 2:1 5.5" top and bottom bezels are 15mm. It's around the same for 5ii. It's just bottom heavy.
Idk, maybe they regretted making L4 long. This way, at least some people might want it as it is a smaller phone if the chip is Snapdragon and performs OK for daily use.
[ This Message was edited by: Ppl on 2021-01-24 21:14 ]
Posted: 2021-01-24 20:02:24
Hawk12 Posts: > 500
L4 has 3 rear cameras.
Wide, ultra wide and useless depth.
This one has dual system.
This really targets Sharp midranges.
I would not expect low price, Ace is was expensive than 10+.
Posted: 2021-01-24 20:30:15
cool_sauce Posts: 326
Why not just do Xperia 10 reverse the chin into forehead and put a selfie cam there instead of a notch?
Posted: 2021-01-25 00:19:48
Hawk12 Posts: > 500
You can pre-order Pro in Japan on wednesday.
Tweet from Nikoshita (someone who posts about info on upcoming camera gear).
Person claims it is L5.
https://androidnext.info/?p=9779
Is it possible to tell if camera is 16mm or 52mm just looking at it?
[ This Message was edited by: Hawk12 on 2021-01-25 15:01 ]
Posted: 2021-01-25 15:13:29
xpr Posts: 327
No. It isn't 16mm nor 52mm in the first place - it's equivalent to 16/52 in full frame sensor focal length.
[ This Message was edited by: xpr on 2021-01-25 22:28 ]
Posted: 2021-01-25 16:15:19
Hawk12 Posts: > 500
I know, but is easier to say just 16/52 than 16/52 (35mm equiv).
Everydoby does this for cellphones.
Posted: 2021-01-25 16:48:10
