Topic Locked
Asia Pacific
> Sony Ericsson Filipino Users 2
attention mr.
WILLBARROW, have your comment please on the new
T68 software, thnx
goodbye
Posted: 2002-03-06 14:30:00
The only difference between the r520, t39, and t68 is the form factor and screen. All of them are functionally the same.
This post was posted from a T39
Posted: 2002-03-06 14:45:00
@GOwin, the first thing i'd like w/ that mms firmware is the ability to save more picture & to change the current scrčensaver. Regarding sms via gprs, it works fine.
This post was posted from a T68
Posted: 2002-03-06 15:33:00
ferrarista44 Posts: > 500
On 2002-03-06 14:00, GOwin wrote:
Globe's SMS.
To those who have used SMS access by GPRS, does it work?
mine says FAILED....
others work? how? hmm....
On 2002-03-06 14:24, pot wrote:
Hey does anyone knws hw to delete d address in d enter adres ?
the list can only contain up to ten addresses, then the first one you entered goes out of the list upon entering an 11th address.
[ This Message was edited by: ferrarista44 on 2002-03-06 16:10 ]
Posted: 2002-03-06 16:08:00
@ferrarista, be sure ur gprs signal is strong. Kasi kung medyo mahina yung signal mo,sms via gprs really fails.
Posted: 2002-03-06 16:13:00
sms via gprs.... fail... 2 days na
use gsm instead... weird...........
cant send/retreive email using R520m... ahhhh! have to check my configuration w/ t68 tom
[ This Message was edited by: dan47 on 2002-03-06 16:16 ]
Posted: 2002-03-06 16:15:00
This is a URL of some software for our T68
Here
ArnoldC's Note:
These are developer software. Note that the MMS Composer will only work if you have MMS firmware version in your T68.
Check the
existing post of the EMS Converter.
[ This Message was edited by: arnoldc on 2002-03-06 17:08 ]
Posted: 2002-03-06 16:53:00
me too! SMS over GPRS hindi nagsesend since two days ago. SMS over GSM na uli...
Posted: 2002-03-06 17:05:00
are we sensing na yung free GPRS access is almost over!?! =(
Posted: 2002-03-06 17:09:00
this is terrible...
i cant send/retrieve email using my r520...
is it my unit or it's the network?
ill try the t68 later.. hope it doesnt work too, so ill be glad that it's not my R520 unit that has problem.
globe sucks!
Posted: 2002-03-06 17:45:00
Topic Locked
