Market : Accessories wanted : SonyEricsson Lamp
< Esato Forum Index > Market > Accessories wanted > SonyEricsson Lamp Bookmark topic
Page <  12345>
orang3 Posts: > 500
cool ... then you can send 1 2 me ... thks in advance ..
Posted: 2002-06-07 19:06:00
loonee Posts: 374
Hmmm... i think i want the lamp too now... its nice!!!
Posted: 2002-06-08 03:48:00
Fahed_2000 Posts: > 500
I live on the third floor withought a lift, and the staircase is bit dark (not a single bulb) i thought that it would be useful then
I Just need someone who has it to tell me the approximate resistance (or curent it consumes) of the original lamp.
I don't want to rist damaging my battrery in any possible way.
Posted: 2002-06-08 05:28:00
Eamonn Posts: > 500
how exactly do u plan making it? how can the batt. get damaged?
Eamonn
[ This Message was edited by: ejasim on 2002-06-08 18:30 ]
Posted: 2002-06-08 19:28:00
moua Posts: 91
i try to plug a led on my T20e (same connector than T6x),
but first, check the voltage :
3,74 volts, - on pin 9, and + on pin 11
i try to plug a blink circuit with a led, who work with 3V,
it's blink, but the light is VERY low,
the sonyericsson lamp should be a very low consumption led
PS : sorry for my bad english
[moua]
[ This Message was edited by: laffen on 2002-06-18 00:55 ]
Posted: 2002-06-09 22:38:00
Eamonn Posts: > 500
Thanks for that although I don't understand anything to do with physics...
Posted: 2002-06-10 17:23:00
moua Posts: 91
it's not really hard... you can DIRECTLY plug a LED on the phone,
but use a low consumption led.
[moua]
Posted: 2002-06-12 17:10:00
Eamonn Posts: > 500
like the ones that are on computer cases?
Posted: 2002-06-12 17:13:00
Clould it be a laser diod, if it is the problem is that they cost arounds £50 down here
Posted: 2002-06-12 21:31:00
Eamonn Posts: > 500
It doen't look like a laser because if u look at the image below, the glare is too much for a lazer & also if u take a 'head on' pic of a lazer, there is a black dot in the middle...
Eamonn
[ This Message was edited by: ejasim on 2002-06-12 20:38 ]
[ This Message was edited by: laffen on 2002-06-18 00:54 ]
Posted: 2002-06-12 21:36:00
Page <  12345>
