Sony Ericsson / Sony : General : ///Ericsson Forum - Infos and support - For help contact your local eriman! Details in the 1. post!
General
Sorry no luck with finding a multimeter.
I did get a r380, just wondering does anyone know would a bsl battery fit into it?
I have a larger bus battery that I can sort of squeeze into it and it works temporarily (while I squeze the phone)
Thanks
Posted: 2022-01-01 21:52:48
Sad to hear - anybody else out there?
At least I can help a bit with the R380: as far as I know, the only battery for that phone was the BST-10 with the included stylus.
Edit: While that one has the same connector and the same voltage, the dimensions are different. But it seems you can still get some now and then - and they are Li-Ion batteries that are rather large for their capacity (950mAh) so you might be able to find a new mobile phone battery that fits into the case.
[ This Message was edited by: flipphone on 2022-01-04 23:57 ]
Posted: 2022-01-05 00:46:58
Greetings what program is suitable for Ericsson R380 Upload a new firmware? Thank you
Posted: 2022-04-05 17:16:05
Is the Ericsson R380 the satellite fone one? Is Bobafett still active here?
Posted: 2022-05-11 12:36:25
R380 is the "smartphone". R190 and R290 are the satellite phones.
Posted: 2024-01-04 10:33:12
