Topic Locked
General
> Apple Macintosh and Sony Ericsson issues
@ mustu
no software necesary! use the OS X AddressBook, connect to your phone with the little bluetooth icon, and do a right click (or ctrl-click) on the phone number!
Posted: 2004-03-08 21:04:18
that sms thingy doesnt work with a p800 or p900 though does it? i cant even dial out without editing some xml inside the adress book app and i only got that working once (or did i dream that?!)
i got a feeling that the symbian operating system does not allow for this sms and dialing out which would also explain why incoming calls do not produce a contact when using clicker.
pain. in. arse.
oh and by the way moderators - a seperate forum would be nice. just look how many posts there have been on this thread in such a short space of time!
[ This Message was edited by: meatmcguffin on 2004-03-08 20:37 ]
Posted: 2004-03-08 21:34:28
@meatmcguffin I don't know whether we will get a new forum - at least this thread has been made sticky so it's a start. I never guessed when I started this thread only 2 days ago, on Saturday, there would be such a massive response. To be honest, I'm surprised and rather pleased with myself!!
So admins/moderators: are you listening? We want a *separate* forum ...
As to your specific sms problem, it might be worth trying Phoneagent [see near the start of this thread] to see if your p800 works with it.
Hope this helps,
David
Mac iBook, SE t610 and Bluetooth - a winning combination!
[ This Message was edited by: thewiccaman on 2004-03-08 21:07 ]
Posted: 2004-03-08 22:06:29
hey all! great thread, keep it going! my problem is thus: i got a G3 300 mhz mac running 9.1 and it works great (mac os does look lovely on 21 inches of pristeen glass) just the audio doesnt work... ive checked the volume controls and its set to the minimum volume... with no way to change it... i can drag the volume slider up but once i let go of the mouse it returns to its original position... i need help!! oh yeah and will gettin osx make a difference to my sound problem?
Thanx for time
Posted: 2004-03-08 23:34:00
it doesnt seem like the phoneagent thing works on a p series phone.
for anyone whos interested in getting the adress book dial out working for the p900 or other phones then this could be useful:
note: this might not work, i think my problem was that im not using the latest p900 firmware - oh and make sure you have the latest bluetooth update for the mac. and dont worry if this doesnt work its simple to change back!
1) control click the address book application and select show package contents
2) open the following folders:
contents -> resources -> telephony.bundle -> contents -> resources
3) there should then be a file called ABDeviceCommandSets.plist, copy this file to somewhere safe just in case.
4) open the original file with TextEdit
5) scroll down to near the end and change the "p800" to "p900"
6) restart the mac (just in case) and give it a try, oh and tell me on this forum if it works!
if this doesnt work then you can always change it back, or if you majorly mess it up then you can always just copy back the copy you made. simple!
this works for other phones as well, although with these you can add strings in the way that other phones have been added previously. hope this helps all you esatomacs out there!
Posted: 2004-03-08 23:50:46
for my t68 i use a freeware called romeo
for my p800 i am currently trying the new salling clicker...i like that feature where i can control my mouse with my styli...great have to buy this software when money comes.
Posted: 2004-03-09 02:49:47
@lozishere
have you always had the sound problem or is it recent? and yeah id upgrade to panther, just make sure it'll operate on a g3 system. best bit is its completly backwards compatible with 9.x
Posted: 2004-03-09 17:33:39
problem has been around for.ages... not from the beginning though, mind. @all: would 10.2 (jaguar, not panther: i cant afford it) run on a G3 300 mhz with 740mb (i think) of RAM? tia
p.s. thanks for the quick reply!!
Posted: 2004-03-09 19:22:00
@lozishere
it appears that panther will work on a power mac g3 with 128mb of ram so its almost guaranteed that jaguar will run on this, as long as it has built in usb support (for some reason)
there's a bunch more on the apple website
http://www.apple.com/macosx/upgrade/requirements.html including some incompatibility issues. is jaguar still for sale anywhere?
Posted: 2004-03-09 22:44:27
oh sh*t! my mac doesnt have usb! would a usb pci card do? any ideas of where to get one?
Posted: 2004-03-11 21:57:45
Topic Locked
