Topic Locked
General
> Apple Macintosh and Sony Ericsson issues
If no one has an answer or has found anything that works... I've jsut got hold of this
http://tnkgrl.wordpress.com/2[....]y-ericsson-k850i-isync-plugin/
Posted: 2007-12-23 19:11:33
A fully working, tested and supported K850 plugin is available from
http://www.feisar.com/
Posted: 2007-12-26 14:52:21
I did a search for k810i and iSync but came up with nothing. I see on apples site that the k790i and k800i are supported by iSync 2.4 (OSX 10.4.10 MacBook) but when I try to connect my k810i it says it's not supported. Isn't this the same phone internally to the k800i? Why does Mac suck so bad at this? And does OSX 10.5 have compatibility for the k810i? I don't really want to buy a plug-in but it seems that is the only option.
Thanks.
Posted: 2008-01-12 08:29:57
The K810i is not natively supported by any version of iSync. Neither is it the same phone as the K800i - just similar.
A plugin for the K810i is available from
http://www.feisar.com/ - Apple is now leaving support for most new phones up to the manufacturers and third-parties, so you could be waiting a very long time for Apple to provide support.
The plugins on feisar.com will soon be linked to from both Apple's and Sony Ericsson's sites, so you can be assured of their quality, support and suitability for the job.
Posted: 2008-01-12 23:41:10
Cheers!
Posted: 2008-01-13 00:55:13
Just wondering will a w960 work with my macbook pro and run isync without any problems?
Posted: 2008-01-18 15:44:42
and when it comes to updating will it work fine on a mac?
Posted: 2008-01-18 15:54:29
Dont know if anyone has posted anything about this yet, but there is a piece of software called 'Itunesmywalkman'. It allows you to synchronize your phone with Itunes for music and photos. I've not used it as I have a PC at the moment, but looked into cos I'm thinking of going Mac.
http://www.versiontracker.com/dyn/moreinfo/macosx/27888[ This Message was edited by: Windowlicker on 2008-01-31 20:50 ]
Posted: 2008-01-31 21:49:19
I've noticed iSync isn't sending all of my calendars to my K850i, only some of them. I can't seem to find anywhere that lets you choose which calendars are sent across, or is it just a bug?
I'm running 10.5.2 (but I had this problem on 10.5.1, and I think Tiger too), using the plug-in from Feisar.
EDIT: Sorry.. my fault.. I forgot you can click on the device and set options from there. I kept looking in Preferences.
*doh*
[ This Message was edited by: Memzee on 2008-02-26 22:22 ]
Posted: 2008-02-26 10:01:02
Im having problems getting pics off my k850i to my mac powerbook g4(running tiger)... it just hangs...
Posted: 2008-03-06 02:28:45
Topic Locked
