General discussions : Product reviews : Z1010 user reviews
< Esato Forum Index > General discussions > Product reviews > Z1010 user reviews Bookmark topic
Page <  12345678>
BobaFett Posts: > 500
Another new user here. Do like the big keypad and screen, its a bit weird at usage, its my first clamshall fone, have to learn how does itfit the best my hands.
Posted: 2005-02-09 21:15:14
is that normal,that even the batt is full charged, on the screen is still written "charging"? i charged it ca 5 h long in off mode and when i disconnected it, it turned off, but the fone was already off, as i mentioned.
Posted: 2005-02-10 16:40:04
Matteus Posts: 372
Normal! I found the same.
This message was posted from a T39
Posted: 2005-02-10 20:12:28
weird, that u cannot set the background light and at taking a pic with the cam, u cannot set darker or lighter etc aswell.
Posted: 2005-02-11 13:02:16
whats the max mem card accepted in z1010?
Posted: 2005-02-12 16:16:48
emanuelj Posts: > 500
128 mb ms duo
Posted: 2005-02-12 22:03:22
Thx! How do u format the mem card?
Posted: 2005-02-13 21:44:52
I tested z10 with cdt10 charger, the led didnt turned to green even after 8 hours and it was still charging, but the batt was full. Fw or hw problem should it be, weird bug.
Posted: 2005-02-19 17:08:22
Matteus Posts: 372
It is the system as in Palms. The led do not change the colour. You must look the watch. For z1010 4-5 hours are enought, Palm needs 2 hours charging.
Posted: 2005-02-20 06:11:35
Thats ok, but its a weird bug and se should fix it.
Posted: 2005-02-20 08:20:40
Page <  12345678>
