Regional : Americas : sim locking in US - vs and at&t
< Esato Forum Index > Regional > Americas > sim locking in US - vs and at&t Bookmark topic
robertk232 Posts: 22
OK, say i do unlock my ATT T68i, how do i go about getting a different SIM card, would I have to go out and but it somewhere? If i wanted voicestream, sorry i have no clue
Posted: 2002-08-03 22:34:00
waddie Posts: 119
Mindreader, if you have an unlocked phone, you don't necessarily need to insert a different SIM card to make sure it is really unlocked. you can just press a few buttons and it will show up if the phone is completely unlocked or not...but if you really want to buy a different SIM card, then buy one from AT&T, it's that simple.
Posted: 2002-08-04 06:47:00
kaaspad Posts: 75
does anyone know what the "second" pin number is for, and what it is by default ? some things ask me for PIN 2 is there a default setting for this ? is it a sim issue or a phone issue ?
Posted: 2002-08-10 00:28:00
rj Posts: 95
kaaspad.
i dont know the default number for pin2 code. pin2 code can be used to allow the usage of phones' features like call barring etc.
u'll be able to activate the ' block callers and accepted list options available for use '
Posted: 2002-08-11 10:04:00
zasinets Posts: 3
hi guys!
how do i enter this signs on t68m for unlocking?
Thanks
P.S. just a new guy yet
Posted: 2002-08-24 13:38:00
shadow_wolf Posts: 0
the are directions on the joy stick in stand by is right .
Posted: 2002-08-24 22:05:00
zasinets Posts: 3
Thank You shadow_wolf for your help. I appreciate it.
Posted: 2002-08-25 03:07:00
