Sony Ericsson / Sony : Symbian phones : P910 disassembly and painting FAQ (lots of photos)
Symbian phones
but if you paint how will you protect the numbers/abc that is on the keypad?
Posted: 2005-06-03 02:28:43
well you take the whole flip apart and set the numbers and such aside. Just paint the outsides of the flip.
Posted: 2005-06-03 04:12:31
howdy guys, been reading for ages, haent posted often, but i took the risk too, i stripped down the phone at work today ( took about 25 mins hehehehe) did two under coats, four coats in mat black, and im now on my third coat of metallic charcoal grey, a model car colour, i was using airbrush at work, but am using spraycan for the last coats of gloss, i wreckon another 5 should do it.
will be starting on the gloss in about an hour, i have it under two lamps at the moment, if anyone know how i can post pics, ill put some up of my progress
thanks
ghost
Posted: 2005-06-03 10:10:05
good job mate!!!!
excellently presented "how to" guide.
youve done a better job than i ever could!
Posted: 2005-06-03 10:24:34
oh i see.. when u take it apart.. the numbers n abc will be taken out as well leaving it just blank holes for me to paint
Posted: 2005-06-03 10:39:44
good to see other people are taking the risk and painting their phones. You can post pics by clicking "Attach picture" which is right above the submit button.
Posted: 2005-06-03 18:19:03
ok, well, i have a small warning for people, lol, i had a wee lil accident
from the pics you can see below, i was extremely happy wiht how my phone turned out, exstatic even, spent alot of time and energy on this, about 6 hours worth of painting, and 24 hours worth of drying, lol
so all was done, jsut had to reassemble.... easy right?
well, seems i had put too many coats on, which made everything jsut a lil bit thicker, so was jsut a lil bit harder to put back together.......
in my rush to put it back together, i was, erm a lil bit too eager, lol, and erm, put a bit to much pressure on a corner of the case, teh one closest to the bottom right of the screen..... can anyone guess whats hapend?
yes, thats right........ i put pressure on the screen, and erm, to be be blunt...... i f*#ked it. phone starts up with a big blue mass in the bottom corner, and ofcourse, it jsut goes down hill from there..
now heres the good point, my phone is insured, so i rang up and claimed an "incident" and have been given $1200aud to spend on a new phone of my choice, but i dont know what to do, get another p910i, or try and xda IIs, which i havent minded the look of....
anyone have a "NEUTRAL" opinion on which way i should go?
lol
anyway thanks for your help knight, hope you like how it turned out, even if it is f*#ked
sorry about the quality of that last pic, please let me know what you think.......
oh yeah, and depending on what i decide, my p910i ( with damaged screen) 2 syn stations and chargers ( 1 set from my p900 i had before) amy be going up for sale, i think if you jsut change the screen is interchangeable between the p900 and the p910, if you get my drift
ta
ghost
Posted: 2005-06-04 12:47:13
That is such a shame to hear that you messed your phone up. Let this be a lesson. One coat is not enough, a few coats is good, but don't go overboard or the phone won't fit back together. Also, if its fitting tight, don't force it!
Posted: 2005-06-04 13:38:06
lol
ta
ghost
what kinda insurance is this?? and they let you keep the phone as well??? i be interested in the broken p910 maybe. lmk thanks
Posted: 2005-06-05 02:35:57
Thanks for your helpfull guide .
Posted: 2005-07-13 09:38:43
