Sony Ericsson / Sony : UMTS / 3G : Code to unlock the vodafone sim lock
< Esato Forum Index > Sony Ericsson / Sony > UMTS / 3G > Code to unlock the vodafone sim lock Bookmark topic
grex Posts: 401
has anyone tried the unlocking site that dgilmartin suggested? and it appears to be £19.99 for that one
can anyone recommend anywhere else online that can unlock a UK Vodafone w900i (cheaply if poss.)
cheers
Posted: 2006-02-08 18:03:37
batesie Posts: > 500
thats pretty cheap really! i'd go with the £19.99 option...
Posted: 2006-02-08 18:13:17
Syrus_20 Posts: 91
You may be able to pull a fast one on Vodafone, I heard bout this elsewhere, not sure tho. Am gonna give it a try myself soon enough. Well what you do is call up Vodafone and tell them you got a contract through but your number is being ported over, and meanwhile you wanna use your old simcard in it cause its still holds your current number, and they might go and give you the unlock code for free!
May work...may not work...worth a shot!
Hope it helps, if it dont work then slap out £20 for it i guess! Think this site does it - http://www.vodafoneunlockcodes.co.uk/ *Also think its mentioned before).
Posted: 2006-02-19 01:32:25
Dogmann Posts: > 500
My advice would be for the small amount extra it makes sense to get the unlock code direct from Voda as at least then if whilst flashing to latest software the phone locks again you have the original code and some one who will be obliged to unlock your phone again for free. Cheap usually works out more expensive in the long run.
Posted: 2006-04-07 13:13:19
fatreg Posts: > 500
i thought voda did it for free if you were "going" abroad for a longish time?
Didnt you say you were moving the Outer Mogolia for 6 months batesie?
fatreg
Posted: 2006-04-11 01:11:41
solidsingh Posts: > 500
ill do it for £5 , jus PM me ur IMEI
Posted: 2006-04-11 01:38:52
terminatordongle.com Posts: 17
today the TMS team released v2.08 software with huge update: now w900i direct unlock is supported via 2in1 multi-server cable. of course no test point to mess around with and solution fully tested and working.
both the TMS credits and the 2in1 cables can be found here:
http://www.terminatordongle.com/cmd.php?ad=221073
be sure to post your results!
Sincerely,
--Corey
Posted: 2006-04-15 09:40:10
lomb Posts: 52
I used the total server worked ok for 5 handsets
the link
http://www.totalmultiserver.com
Posted: 2006-06-27 19:18:12
