Sony Ericsson / Sony : UMTS / 3G : O2 3g
< Esato Forum Index > Sony Ericsson / Sony > UMTS / 3G > O2 3g Bookmark topic
Page <  12345>
darrengf Posts: > 500
I have been using Orange 3 g and o2 3g.
very impressed with them both, However i have only been able to used o2 in one place.
On Orange I have used it in most places i go with out problems.
I have even got a Orange 3g signal in the country side where there isnt o2 or vodafone at all.
Very happy with it
Posted: 2006-05-28 14:26:46
mrvanx Posts: 91
Im planning on getting the SE P990 Once it comes out......Now i am currently on a 1 month rolling contract with O2 would i need to get anything enabled/upgraded to take advantage of the 3G service when i get my P990????
I can use the full http GRPS gateway and opera works fine on my P900 at the moment so data seems to be ok but what about 3G?
Posted: 2006-05-31 00:16:08
SCORPIONKING1982 Posts: > 500
you may need a new sim card and/or 3g activated on your account, youll have to speak to customer services about what exactly you personally need though.
you wont need any different settings in your phone.
Posted: 2006-05-31 00:52:53
mrvanx Posts: 91
Yer they should be able to sort me out. They did a really good job of transfering my number from PAYG to contract when i took the online sim card offer....so i should be fine once ive got the P990.
Posted: 2006-05-31 19:57:59
englishmanabroad Posts: 163
Guys - just ordered up my K800i on O2. For now I just want it because it is the next one up from my K750i - I'm not bothered at the moment about 3G.
My question however is - do you think the phone will be able to access GPRS - WAP etc etc from a regular SIM? I buy a phone from O2 each year because they do not lock them or brand them excessively - but need to be able to use my work SIM (orange) - in it when needed. From the threads I think that if I do not activate the 3G SIM supplied with the phone it should be no different from using the K750I on different networks...Or am I in for a nasty surprise?
Posted: 2006-06-30 22:53:32
Aware Posts: > 500
@englishmanabroad: you should be able to switch off 3g in the 'Settings/Connectivity/Mobile Networks' menu on the phone.....
@mrvanx
Vodafone added 3G to my account over the phone; O2 told me I had to purchase a USIM to use the service
Posted: 2006-06-30 23:20:13
Thanks! @Aware.
I will change the settings to switch off 3G- just thought that if I activated the new 3G SIM with O2 - it would deactivate my existing O2 SIM - I guess I should wait until the thing gets delivered
Posted: 2006-06-30 23:24:34
m100 Posts: 189
You should be able to use both 2G and 3G sims as long as you have the settings. This message was posted from a K700i
Posted: 2006-07-01 00:06:31
Residentevil Posts: > 500
On 2006-05-17 00:46:29, jcwhite_uk wrote:
Coverage for o2. 3G is in dark blue:
That is not much 3G coverage outside London.
Posted: 2006-07-01 08:06:54
peanut Posts: > 500
On 2006-06-30 23:24:34, englishmanabroad wrote:
Thanks! @Aware.
If you activate the 3g sim it will deactivate your usual sim. You may be able to use your 3g sim in a non 3g phone
Posted: 2006-07-01 09:05:09
Page <  12345>
