General discussions >
Product reviews
> Nokia N95 Review
Hi all,
IMHO Handy Taskman as mentioned by Maggflodd is as good if not better than any other.
Thanks for that mutleyboy that explains it i couldn't understand how that was possible.
Marc
Posted: 2007-05-03 20:48:34
Just add to the quality review above....
I have tested the phone as a music player that is also capable of dowloading its own music without the need for a PC. For Free....
For this example i used the RSS feed for
http://www.dnbradio.com which is hosted by feedburner and WLAN.
First of all i connected my N95 to the internet via my BT Home Hub. easy enough just needed my WEP Key.
Then from the webrowser you have option for 'Feeds'
just bash in the address of you fav feeds in here....
Then browse the Feed or podcasts (i prefer not to use the word podcast as its not just for P
iePods.
Then pick the one you want and download!
i downloaded 3 of them and then it gave me the option to save them...
I Checked the 'Log' in the Applications folder and it shows all the comms including phone calls Texts Wap 3G GPRS WLAN etc
the WLAN details show.... (this was this slow as i paused it half way though to make a phone call but the counter kept running - but i got about 95-105KBps)
All i need to do now is plug in a phat pair of headphones and off i go with 3 different 1 hour mix sets!
And this phone powers my sennhiesers better than my 20Gb Sony walkman HD5! but the quality is just slightly more inferior than the walkman, can only tell with a good pair of headphones though.
Over all it beats my Sony Ericsson W900i - Sorry SE!!!
‘Imagination is more important than knowledge’ - Einstein
[ This Message was edited by: batesie on 2007-05-03 21:35 ]
Posted: 2007-05-03 22:34:13
How long does the battery last driving those HUGE head phones?
Posted: 2007-05-06 17:07:19
@QVGA, yeah I mentioned that in the review. N80's screen is smoother.
@Dogg, I'm not using anything to convert. I don't convert movies. I meant that the camera's own video recording doesn't compress well.
You are right though I didn't talk about the browser.
I like it,
I like the tiny mouse and the speed however I do not like the fact that it seems to load the 'style sheet' last and very slowly which can cause a lag on more complex sites. Opera is good however it seems ot have cookie problems.
I'm still waiting for flash intergration to be honest!
@batesie, I use Handy Task.
@Tinax, I think the n95 is better than pocket pcs due to speed. PPC's are usually slow, and need to be restared alot.
both have alot of support.
@samlala, it wasn't a charging speed competition... I was pointing out it takes around an hour (perhaps I should stop watch it for people who want to go number crazy...) because although the battery isn't super long, it takes a bit to charge.
@batesie again, Thanks for the addition! Feels like a community review now!
I wanted to add. Is there anyway of NOT having the red light on when you are recording?
I want to also add that battery life lasts around a day and a half still with usage.
Posted: 2007-05-07 18:31:03
well i used them for 2hours mp3 playback at 70-90% volume and used it as normal during the day and still had life left before pluggin it in at night!
Posted: 2007-05-14 16:04:45
Nokia have begun to release spec on the CPU's used in there phones, so here's the spec on the N95! yes its a dual cpu!
CPU:
Dual CPU
CPU Type: ARM 11
CPU Clock Rate: 332 MHz
3D Graphics HW Accelerator
Posted: 2007-05-18 15:22:58
For anyone that wants to know the full specs via wap/html lite etc, here they are
Amazing what can be fitted into a device that weighs only 120grams!!!
Nokia N95 Technical Specs
Operating System:
Symbian OS v9.2
Developer Platform:
S60 3rd Edition, Feature Pack 1
Frequency Band:
GSM 850
GSM 900
GSM 1800
GSM 1900
WCDMA 2100
Regional Availability:
Africa
Asia-Pacific
China
Europe
Middle East
Display:
Resolution: 240 x 320
Color Depth: 24 bit
CPU:
Dual CPU
CPU Type: ARM 11
Memory:
Max User Storage: 160 MB
NAND Memory: 256 MB
SDRAM Memory: 64 MB
~18 MB Free Executable RAM Memory
Memory Card: Micro SD
Max Memory Card Size: 2 GB
Memory Card Feature: Hot Swap
Unlimited Heap size
Unlimited Jar size
Network Data Support:
HSDPA
WCDMA
EGPRS
GPRS
HSCSD
CSD
OMA Device Management:
OMA Client Provisioning v1.1
OMA Device Management v1.1.2
Additional Info
OMA Data Synchronization:
OMA Data Synchronization v1.2
Additional Info
Local Connectivity:
Bluetooth 2.0 +EDR
Infrared
Mini Stereo Plug 3.5mm
Mini USB
Nokia Audio Visual Plug 3.5mm
UPnP
USB 2.0
USB Cable Nokia DKE-2
USB Mass Storage
WLAN
Additional Info
WLAN Support:
802.11b/g
WPA
WPA2 (AES/TKIP)
Additional Info
VoIP:
Nokia VoIP 2.1
Bluetooth Profiles:
A2DP, AVRCP, BIP, BPP, DUN, FTP, GAVDP, GOEP, HFP, HSP, OPP, SAP
Java Technology:
MIDP 2.0
CLDC 1.1
JSR 135 Mobile Media API
JSR 172 Web Services API
JSR 177 Security and Trust Services API
JSR 179 Location API
JSR 180 SIP API
JSR 184 Mobile 3D Graphics API
JSR 185 JTWI
JSR 205 Wireless Messaging API
JSR 226 Scalable 2D Vector Graphics API
JSR 234 Advanced Multimedia Supplements
JSR 75 FileConnection and PIM API
JSR 82 Bluetooth API
Nokia UI API
Java Verified Root Certificate:
UTI Root
Symbian Certificates:
A, B, C, D
Browser:
HTML over TCP/IP
S60 OSS Browser
WAP 2.0
XHTML over TCP/IP
Additional Info
Flash Lite:
Flash Lite 2.0
Messaging:
MMS
MMS+SMIL
SMS
Email Protocol:
IMAP4
POP3
SMTP
Digital Rights Management:
OMA DRM Forward Lock
OMA DRM v1.0
OMA DRM v2.0
Windows Media DRM 10
Additional Info
DRM Delivery Method:
HTTP Download
MMS
OMA Download
Additional Info
Camera:
Resolution: 2582 x 1944
Sensor: CMOS 5.0 Megapixels
Focal length 5.6 mm
F-Stop/Aperture f/2.8
Focus range 10 cm to infinity
Digital Zoom: 20 x
Image Format: JPEG/Exif
Feature: Auto Focus, Carl Zeiss Optics, Flash, Red-Eye Reduction, Self Timer
Video Resolution: 640 x 480
Video Frame Rate: 30 fps
Video Zoom: 10 x
Video Format: H.263, MPEG-4
Secondary Camera:
Resolution: 320 x 240
Focal length 43 mm
Digital Zoom: 2 x
Video Resolution: 176 x 144
Video Frame Rate: 15 fps
Video Zoom: 2 x
Video Format: H.263
Video Features:
Video Call
Video Editor
Video Player
Video Recorder
Video Sharing
Video Streaming
Video Formats:
3GPP formats (H.263)
H.264/AVC
MPEG-4
RealVideo 7,8,9/10
Additional Info
Audio Features:
Audio Equalizer
Audio Recording AAC stereo, 48kHz
Audio Streaming
Music Player
Stereo
Audio Formats:
AAC, AAC+, eAAC, eAAC+, MP3, MP4, M4A, WMA, Mobile XMF, SP-MIDI, AMR (NB-AMR), MIDI Tones (poly 64), RealAudio 7,8,10, True tones (WB-AMR), WAV
Additional Info
Document Formats:
Excel, PDF, Powerpoint, Word, Zip
Graphics Formats:
BMP, EXIF, GIF87a, GIF89a, JPEG, JPEG 2000, PNG, WBMP
Extra Features:
Digital Recorder
GPS
OpenGL ES 1.1 Plugin
PoC (Push-to-talk over Cellular)
Stereo FM Radio
Stereo Handsfree Speakers
Still Image Editor
SyncML
Themes
TV Out
Visual Radio
Keypad Description:
2 Labeled Soft Keys
5-way Scrolling
Dedicated Media Keys
Side Key Mat
Power Management:
2.0mm Charger Connector
Battery Capacity:
BL-5F 3.7v 1100 mAh
Talk Time (estimated):
GSM: up to 4 hours
WCDMA: up to 2.7 hours
Standby Time (estimated):
GSM: up to 9.3 days
WCDMA: up to 8.3 days
Size:
99 x 53 x 21 mm
Weight:
120 g
Posted: 2007-05-18 15:31:21
wow, that was nice to read what I have.
Now if only I had double the ram. I'd be set!
Posted: 2007-05-21 04:44:25
Its an impressive spec eh ;-)
Posted: 2007-05-21 08:48:41
i found a really cool feature of the N95, when you are on the phone to someone you can play music down the phone to them at the same time! and whats better is the person i was calling said how good the quality was.
i simply opened music player and played an MP3 and instead of coming out of the stereo speakers it came out of the ear peice and i could still clearly hear both the person i was speaking to and the music.
the other good part was the music wasnt too loud in my ear and couldnt be heard by anyone further away from me.
im still shocked by the seamless quality of this. very impressed nokia!
Posted: 2007-05-25 12:13:30
