Sony Ericsson / Sony : UMTS / 3G : "Insert USIM" plz tell me how to overide
< Esato Forum Index > Sony Ericsson / Sony > UMTS / 3G > "Insert USIM" plz tell me how to overide Bookmark topic
Page <  123>
gaming_guy Posts: > 500
On 2008-03-05 19:25:47, Challe wrote:
Iīve downloaded a prog. that makes the patch for u (SIMLockPatchGen) and I installed tha patch it gave me but now it says "insert correct SIM card" what to do? :'(
if u use setool2lite make sure you select bypass db2020 security (next to the phone model list) otherwise the patch wont work
Posted: 2008-03-05 19:47:44
Challe Posts: 39
yepp, tried that the first thing I did and it did not work, yet i will try again just to be sure
Posted: 2008-03-05 22:54:54
Challe Posts: 39
Hereīs the log:
Going to execute VKP script....
ChipID:9900,EMP protocol:0301
PHONE IS RED RETAIL PRODUCT
FLASH CID detected:52
Speed:921600
OTP LOCKED:1 CID:49 PAF:1 IMEI:35342701247475 CERT:RED
FLASH CID:52 COLOR:RED
LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005
Flash ID check:897E
Flash props sent ok
only FLASH operation supported in that mode
Elapsed:9 secs.
And still doesnīt work "Insert corredt SIM card" when i use my own. :'(
Need help plz?
Posted: 2008-03-05 23:02:54
Daedalus85 Posts: > 500
Ok, it saying "Insert USIM" does not means its locked, hasn't got anything to do with it.
If it's locked and your using a different network sim in it, it'll just say something like "Insert Correct USIM".
Just saying "Insert USIM" means either the sim card, or the sim card reader on the phone, is faulty. Have it repaired under warranty and it'll be fine.
Posted: 2008-03-05 23:44:59
Challe Posts: 39
read all the posts and you will see why I want to do this at home
Posted: 2008-03-06 06:43:29
Yeah, and my point still stands.
Let me explain clearer.
It is broken.
It needs to be fixed.
Posted: 2008-03-06 11:35:53
Challe Posts: 39
no, it is not broken, I have not mentioned this but is i donīt have a sim in and i start it it says "insert sim" when i do insert my own sim it says "insert correct sim" so the sim reader is not broke
Posted: 2008-03-06 19:50:48
Right, well I didn't see the bit where you said "Insert Correct USIM".
So yes, it's locked, get it unlocked, simple.
Posted: 2008-03-06 20:22:10
Challe Posts: 39
how do i unlock it?
Posted: 2008-03-06 20:25:33
It's a bit of a grey area, as the vast majority of phone shops won't unlock them.
Find out where your local independant phone dealer is, or the local person who sells accessories etc for phones.
Posted: 2008-03-06 22:29:55
Page <  123>
