General discussions : Rumours : SMSD 256 mb ?
< Esato Forum Index > General discussions > Rumours > SMSD 256 mb ? Bookmark topic
ainamrev Posts: > 500
Das fook someone with lots of cash buy one tell us if it works + its the 128 x 2 system so theoretically i.t should work with current firm wares.
Posted: 2003-06-26 19:34:50
thundercat Posts: 80
i'd say the pic is definitly a fake.. but that grey p800 looks excellent! i want one now!
Posted: 2003-06-27 15:53:18
sxt173 Posts: 189
The document noted above is a pretty good indicator that there will be bigger MS DUO's.
LINK
FYI, the magicgate ones do support above 128MB, and they will work in the P800. It's just that the P800 cannot use the extra "security" features on the magicgate (which should not be a big concern).
Posted: 2003-07-07 17:59:57
demon106 Posts: 193
That pic is so clearly a fake.
Look to the right of the Duo, both the actual duo and the reflection, and you will notice the area is lighter than the rest. Looks like hes taken a 256MB standard memory stick, and then removed half of it (using the Rubber Stamp tool) to make it Duo-sized. Notice how this light area is exactly the same shape and size as the end of a standard MS.
A good fake at first glance, but not good enough
Andy
Posted: 2003-07-07 18:38:18
kal_59 Posts: 91
but guys if u see the reflection of the 256mb MSD, u will see that it has the right reflection, and i think its quite difficult to do that... if he did that also, then i think hes one shit f**k of a mastermind!!!!
Posted: 2003-07-08 01:19:16
jepaz Posts: 131
Even if it is really true or exists, it will not work with P800.
Posted: 2003-07-08 06:58:23
viper7 Posts: 69
"Even if it is really true or exists, it will not work with P800."
Why??? I appreciate the fact that SE have said it supports upto 128mb, however, I believe from looking at their documentation this is due to this currently being the largest size available...check out pg 13 of;
http://www.sonyericsson.com/images/spgc/CWS31AFW_8654_27_0_1090.pdf
Why would they say a larger size is supported when Sony may never have plans to make a larger capacity MS Duo???
Posted: 2003-07-08 14:14:15
yusufl Posts: 138
hey guys
Firstly I doubt the pic on top is true but see no reason why it shouldn't, It does look like a photoshop job in my uneducated opinion,
Secondly the link to the MS for sale isn't even that of a MS Duo it is of the normal MS with the switch selector to select between the 2 128mb on board the same stick, These do exist in the market presently and have nothin to do with the MS Duo. Just my 2 cents anyway.
Posted: 2003-07-08 15:19:28
nils7 Posts: > 500
On 2003-06-26 18:50:03, mmsman wrote:
what the f**k is this
http://www.budgetfoto.nl/info.php?info=02427
I'm Dutch the page is Dutch is says: Not for P800!
Posted: 2003-07-08 20:56:52
