General discussions : Rumours : I bought 256MB MS DUO for my P800!
> Topic Locked
Esato Forum Index > General discussions > Rumours > I bought 256MB MS DUO for my P800! Bookmark topic
gforce23 Posts: > 500
Absolutely absurd stuff. This message was posted from a WAP device
Posted: 2004-05-16 14:23:37
Elrond Posts: > 500
On another forum some1 says, that he tried the same MS DUO and it didn't work.
Posted: 2004-05-16 14:26:37
Hey elrond, are you talking about hofo? This message was posted from a WAP device
Posted: 2004-05-16 14:30:59
Elrond Posts: > 500
No. I was talking about www.symbianforum.com
Posted: 2004-05-16 14:43:04
DungeonMaster Posts: 312
It is totally imposible. If you know from computer tech then you should know that for every memory besides the data bus there is also an address bus. Px00 address bar is 24-bits so we have 134.000.000 bytes, meaning almost 128mb. So if we put 256mb memory it wont work because the address bus cant handle 25-bit addresses. And NO! you cant update any device to get larger memory because adress bus is made from several metal lines on the motherboard. Cheers! This message was posted from a T610
Posted: 2004-05-16 14:44:22
masseur Posts: > 500
not to mention the fact that no memory stick partner produces 256mb in duo format (only duo pro), and not to mention that I have personally tried 256mb duo pro and 512mb duo pro and not to mention that the official memory stick site lists the p800 and p900 as "duo size only" etc etc etc.
once again I will lock this thread
Posted: 2004-05-16 14:51:46
New Topic   Topic Locked
