General discussions >
Product reviews
> Nokia 6260 Vs SE K700i
6260 is much better.Having said that,many phones are better than the cheap k700.
Posted: 2005-01-31 14:53:19
true, N6260 beats K700.
symbian is so much better than a normal OS.
Posted: 2005-03-30 12:15:58
Quote:Having said that,many phones are better than the cheap k700.8
such has???
Posted: 2005-03-30 12:30:14
Having play with it a bit for a couple of days i must say some goodies and baddies about 6260 - in a context against K700i :
rs mmc expandable memory, smartphone, larger screen, loud external speaker, you can peeping someone with that side-camera!
And some bad things about it : although larger the screen looks grainy -k700 resolution is near perfect, separation between numeric keypad and navigation keypad is not comfortable for daily use, pictures look over exposed-although the sharpness is good.
Posted: 2005-04-07 12:24:00
U have plenty of applicatioos for 6260 while u dont have for k700.
Posted: 2005-04-12 21:48:00
ive had the nokia 6260..... it is slow and annoying!!!
Cant knock da fact its a smartphone.... but that is all its good for!!!
Nothing else.........
ENJOY
Posted: 2005-04-12 21:52:52
I've heard about lots of complaints about the 6260s build quality.(flimsy) So can this phone last?
Posted: 2005-04-12 22:24:13
Forgive me for my questions.Does 6260 have radio? Does it have stereo output?
Posted: 2005-04-12 22:29:27
If it's Nokia 6260 vs
S700i . . . will definitely go for the latter!
Posted: 2005-04-13 04:36:16
