General discussions : Rumours : Sony Ericsson Diana
< Esato Forum Index > General discussions > Rumours > Sony Ericsson Diana Bookmark topic
Page <  123>
Yazan24 Posts: > 500
I think its a T630+P910 cause from the top it has the Pxx0 Shape
Posted: 2004-12-31 12:37:09
govigov Posts: > 500
Where did you get the name diana? This message was posted from a K500
Posted: 2004-12-31 12:41:46
milmino Posts: 454
It's like a t630, k700, t100, p910 combo.
anyway, doesnt look too exiting.
Posted: 2004-12-31 12:46:47
Memzee Posts: 399
Bad photoshop that's blurred to cover up blatant bad spots, and like someone said it's missing a joystick/d-pad, unless it's got a jog dial like the SO505i, in which I case I would expect a different UI to the K700i because you can only go up and down, not left and right.
Also the UI looks like it's been stretched horizontally to make it more of a square aspect ratio (K700i has a rectangular screen, most low end phones are squares, eg 176*220 vs. 128128). This gives the icons a widescreenish effect.
Poor effort.
[ This Message was edited by: Memzee on 2004-12-31 12:09 ]
Posted: 2004-12-31 13:07:48
Very True,
however a jogdial cannot only move up and down, because
u can have down go left and up move right and itll be very handy.
However the stretched screen is right, unless the dimensions are f**ked up its a poor effort.
and the button in the middle could be two left and right
like the t100
-Kamikaze-
The First Owner of a Black/Blue P800
[ This Message was edited by: Yazan24 on 2004-12-31 12:54 ]
Posted: 2004-12-31 13:53:31
Can you pls upload to some other site other than esato? This message was posted from a K500
Posted: 2004-12-31 14:10:28
Memzee Posts: 399
Not really, because if you want to get from, say, folders to connectivity you'd have to scroll through 2 extra icons.
The UI has to match the method for using it, if that makes sense. You can't really have a grided UI unless you can move in all for directions (up down left & right). The UI has to mimic the joystick/joypad, if that makes sense.
Look at the UI of the SO505i in action, and it should become a little clearer:
http://www.clubsonyericsson.c[....]t04/day4/se/cebit04_se4_v2.avi
And the SO5050iS too:
http://www.clubsonyericsson.c[....]t04/day4/se/cebit04_se4_v1.avi
Posted: 2004-12-31 14:16:58
Memzee Posts: 399
Posted: 2004-12-31 14:20:01
Yes I know it has to match the interface.
But have u used the jogdial on the pxx0 Theyre so fast u can scroll through 16 icons in one go, so I dont think its fair that u strike out the possible jog dial all together but its more practicle to have arrows,
Posted: 2004-12-31 14:44:37
Memzee Posts: 399
Ahh, ok. I've never used a Pxx0, not properly anyway.
Posted: 2004-12-31 14:47:58
Page <  123>
